droidus
starting Kodi
Sun Oct 18, 2015 12:45 pm
I am trying to start up kodi. I type "kodi", and it just sits there, and nothing loads. Any ideas how to start Kodi up?
gkreidl
Re: starting Kodi
Sun Oct 18, 2015 1:37 pm
Which OS? Which kodi version? How did you install it?
Minimal Kiosk Browser (kweb)
droidus
Re: starting Kodi
Sun Oct 18, 2015 2:11 pm
sudo apt-get install kodi
Raspbian
How do I get the version of Kodi?
Re: starting Kodi
Sun Oct 18, 2015 2:17 pm
droidus wrote:sudo apt-get install kodi
Raspbian
Raspbian Jessie or Wheezy ??
Retired disgracefully.....
xanthor
Re: starting Kodi
Sun Oct 18, 2015 2:19 pm
Do you have enough graphic memory to run Kodi (at least 128 / 160 MB, ideally 256 MB)? Are you not trying to display Kodi remotely (for example using VNC)? And what exactly do you mean by
droidus
Re: starting Kodi
Mon Oct 19, 2015 12:18 am
Raspbian
Not sure, how do I find out?
droidus
Re: starting Kodi
Mon Oct 19, 2015 12:20 am
xanthor wrote:Do you have enough graphic memory to run Kodi (at least 128 / 160 MB, ideally 256 MB)? Are you not trying to display Kodi remotely (for example using VNC)? And what exactly do you mean by
Not sure - I believe I have the second model. I am using VNC.
And what I mean is when I type kodi, kodi does not start up.
gkreidl
Re: starting Kodi
Mon Oct 19, 2015 12:26 am
kodi doesn't work across VNC, it goes directly to the screen using OpenGL ES. And playing video across VNC connection isn't possible as well.
What do you want to do with kodi, if no Monitor/TV is connected to the RPi?
droidus
Re: starting Kodi
Mon Oct 19, 2015 10:38 am
I would like to know if it is possible to install entertainment software (like xmbc) without having to use it as my primary OS.
Re: starting Kodi
Mon Oct 19, 2015 10:58 am
droidus wrote:I would like to know if it is possible to install entertainment software (like xmbc) without having to use it as my primary OS.
Install Raspbian Jessie Operating System:
sudo apt-get update
fyi XBMC has been renamed to KODI
droidus
Re: starting Kodi
Fri Oct 23, 2015 10:16 pm
I did this. But I am not sure how to start it up and view it.
gkreidl
Re: starting Kodi
Sat Oct 24, 2015 8:10 am
droidus wrote:I did this. But I am not sure how to start it up and view it.
To use kodi as user pi (from the desktop, for example), you have to make some settings in your system. Read the last part of this: viewtopic.php?f=66&t=99866
You should start it from a terminal with "kodi-standalone". If you want to use it from the desktop-file (menu), you should patch the desktop file in'/usr/share/applications' to call kodi-standalone.
Woll
Re: starting Kodi
Sat Oct 24, 2015 8:31 pm
If you changed the settings in Raspbian, would
sudo apt-get update,
sudo apt-get upgrade,
sudo apt-get dist-upgrade,
sudo apt-get clean,
Change the setting back? When I first got my Pi I had trouble with Openelec on the same SD card as Raspbian.
So I have a separate for each at the moment, but ideally I want both on the same card again.
Who ate all the Pi's? Who ate all the Pi's?
Boris Johnson, Boris Johnson,
Re: starting Kodi
Sat Oct 24, 2015 8:35 pm
Woll wrote:If you changed the settings in Raspbian, would
sudo apt-get clean,
I installed KODI 15 from the Raspbian Jessie Repository and it is now a GUI MENU entry, though have not used / configured as yet...........
Woll
Re: starting Kodi
Tue Oct 27, 2015 7:18 pm
On my Pi 2B, running Jessie Raspbian, if I reboot to exit Kodi, it reboots into the desktop again.
