joan
Unknown 433 MHz signal every 5 seconds for 30-40 ms
Sat Oct 17, 2015 1:35 pm
I have a 433 MHz receiver connected to the Pi.
I am experimenting with removing static so ignore all signals if they have not been preceded by 30 ms (or thereabouts) of no high/low change.
I expected to get zero or random triggers.
I am getting a trigger every 5 seconds.
Is there a signal at this period on 433 MHz? It may be an artefact with my software, my initial tests suggest not.
fruit-uk
Re: Unknown 433 MHz signal every 5 seconds for 30-40 ms
Sat Oct 17, 2015 1:44 pm
Someone, a neighbour perhaps, has got an energy monitor (Owl) or something similar?
scruss
Sat Oct 17, 2015 3:09 pm
What kind of 433 MHz receiver are you using? Most of the simple ones have a crude AGC circuit that ramps up the gain slowly until you get a trigger. This allows them to pick up faint signal, but also limits them to very short transmissions with fairly lengthy alternating 'training bits' headers.
I found rigging up a very tiny speaker element between the receiver's output and ground helped me tell if it was a regular signal or just noise.
Pronouns: he/him
joan
Sat Oct 17, 2015 8:06 pm
Thanks both.
I'm using the cheapest 433 MHz receiver I could find on eBay. It came as a RX/TX pair.
I'm not sure if the pulses after the 30-40 ms high edge are data or not. It's difficult to distinguish between static and signal. They may be a signal or any signal may be encoded in the length of the high edge (if I trigger on slightly longer edges I get regular messages at different, but regular, intervals).
fruit-uk
Sat Oct 17, 2015 8:23 pm
Might placing it in a grounded bsicuit tin be enough to block external signals?
joan
Sat Oct 17, 2015 8:28 pm
fruit-uk wrote:Might placing it in a grounded bsicuit tin be enough to block external signals?
That's where I keep my head apart from when outside when I use my rather fetching tin foil hat. :D
My real motivation is to discover if this is an artefact of my software or a real signal. It doesn't actually cause me any problems.
