nohepe
Running LXterminal windows from shell script
Sun Oct 11, 2015 8:56 pm
Hello, I would like to run this script every 5 minutes. It checks needed procesess and start them if they are not running. I need to run mopidy and deluge-web in new lxterminal window. When I try to run this script from terminal, it works without problem. Howewer when this script is scheduled from crontab it only starts deluged(beceuse it is daemon) and nothing more. Script:
#!/bin/bash
mopidy_state=`ps -e | grep "mopidy"`
if [ "$mopidy_state" == "" ];
then
 sudo lxterminal -e mopidy
else echo "mopidy is running correctly"
fi
deluged_state=`ps -e | grep "deluged"`
if [ "$deluged_state" == "" ];
then
 deluged
else echo "deluged is running correctly"
fi
delugeweb_state=`ps -e | grep "deluge-web"`
if [ "$delugeweb_state" == "" ];
then
 sudo lxterminal -e deluge-web
else echo "deluge-web is running correctly"
fi
Alternatively it could be started from some kind of start script after boot. But I would like to have it like this, because it handle also situations when process abnormaly falls/abends without restart of Pi.
Thank you.
W. H. Heydt
Re: Running LXterminal windows from shell script
Mon Oct 12, 2015 2:35 am
Read the manual page on "cron". That is, "man cron" and, probably, "man crontab". Cron is the system "job" scheduler.
nohepe
Mon Oct 19, 2015 8:58 pm
I havent problem with scheduling, but I am not able to start process from script in new terminal window.
For example when I use command:
ps -e
I need those proceses from script started with TTY pts/1 (or any number instead of 1).
If I dont start them in new window, then they are started with TTY ? and thats useless for me.
rpdom
Tue Oct 20, 2015 5:25 am
You can't (easily) schedule a task with cron to pop up in a terminal window on a GUI session. Cron is for running system tasks in the background. They always have a TTY of "?" as they don't run in a terminal.
You might want to consider writing something that auto starts when you log in to the desktop and sits in the background triggering your tasks as needed.
Return to “Beginners”
