Hi guys
I've had a RPi 2 for a week and I want to use it to feed data to flightradar24.com instead of running a pc 24/7.
I bought a Pi with the SD card pre-loaded with NOOBS and I installed Raspbian as the OS.
It took me ages to work out how to install fr24feed (which is the software) but eventually i got that installed no probs and it was working for about 10 mins so I turned it off to put the Pi in the loft. Since then fr24feed hasnt worked and ive contacted them and they said to check the log file but that doesn't exist?! They replied and said to do a clean install of fr24feed. So i started again and this is where my issue is at.
I entered the command to restart fr24feed however when it checks my feeding key it errors due to not being able to connect to the fr24 server. I must mention that I am using an Edimax Wifi USB adapter and have tried using the Ethernet direct from the router. So there is a problem with the network connection somewhere.
I cannot get access to anything on the browser as it says cannot resolve hostname but my IP address is shown as 192.168.0.48 and never changes (It's not static btw).
It was all working 2 days ago but suddenly doesnt work anymore. All of my other network devices work, the USB Wifi is flashing and when connected, the ethernet lights flash as they should.
When pinging 8.8.8.8 is says the 'destination host is unreachable'; when pinging google.co.uk it says 'unknown host'.
Its really frustrating and I havent done anything software/internally as I dont dare change anything!!
Can someone advise on what to do?
Thanks, Max
