I have a blink(1) mk2 (https://blink1.thingm.com/) and I'm using the pypi library (https://github.com/todbot/blink1/tree/m ... ython/pypi).
I don't know if anyone has a blink(1) mk2 but anyway. Also I'm pretty new to python, but not new to programming languages.
In the documentation there is an example:
from blink1.blink1 import Blink1
import time
b1 = Blink1()
b1.fade_to_rgb(1000, 64, 64, 64)
time.sleep(3)
b1.fade_to_rgb(1000, 255, 255, 255)Code: Select all
import time
b1 = Blink1()
b1.fade_to_color(1000, '#ffffff') # Hexdecimal RGB as a string
b1.fade_to_color(1000, 'green') # Named color - any color name understood by css3
b1.fade_to_color(1000, (22,33,44)) # RGB as a tuple. Luminance values are 0 <= lum <= 255Here is the error message:
pi@raspberrypi ~/projects $ sudo python3 test.py
File "test.py", line 5, in <module>
File "/usr/local/lib/python3.4/dist-packages/blink1/blink1.py", line 161, in fade_to_color
red, green, blue = webcolors.name_to_rgb(color)
File "/usr/local/lib/python3.4/dist-packages/webcolors.py", line 384, in name_to_rgb
return hex_to_rgb(name_to_hex(name, spec=spec))
File "/usr/local/lib/python3.4/dist-packages/webcolors.py", line 373, in name_to_hex
u"'%s' is not defined as a named color in %s." % (name, spec)
ValueError: '#ffffff' is not defined as a named color in css3.Is there any way to modify the webcolors.py?
Another "problem" is that the blink(1) mk2 (second version) has two LEDs. Also there is a way to change the color on both LEDs seperetly, but it's not working.
Has anyone a blink(1) mk2 too and can help me?
Sincerely
Mr.Tr33
