hanniabu
Auto Login Questions
Tue Sep 29, 2015 7:22 pm
I have a few questions about auto login:
1. I am currently follwing this instructional to set up auto login:
http://www.elinux.org/RPi_Debian_Auto_Login
It says to comment out this line:
1:2345:respawn:/sbin/getty 115200 tty1
However, my line looks like this:
1:2345:respawn:/sbin/getty --noclear 38400 tty1
So my first question is, can somebody explain the parts of this line? What is respawn, 115200/38400, --noclear, and tty1? Any ideas why mine is different?
2. The next part says to add this line:
1:2345:respawn:/bin/login -f pi tty1 </dev/tty1 >/dev/tty1 2>&1
What are -f and </dev/tty1 >/dev/tty1 2>&1? Also, I deleted the pi user and added another user as one of a few attempts to make it a bit more secure. I'm assuming I should replace the "pi" part with my new username.
3. I still want to setup the auto login regardless, but I would like to know - must a user be logged in to auto-run a script? Does this change if this script is run as a cron job or a service?
Thanks for the help in advanced. As a novice I'm trying to learn as much as I can to actually learn instead of blindly following tutorials.
Re: Auto Login Questions
Tue Sep 29, 2015 8:42 pm
It's a million times easier to forget that ancient wiki entry and use sudo raspi-config to choose whether you login to a command line, auto login to a desktop or auto login to Scratch.
hanniabu
Tue Sep 29, 2015 9:05 pm
DougieLawson wrote:It's a million times easier to forget that ancient wiki entry and use sudo raspi-config to choose whether you login to a command line, auto login to a desktop or auto login to Scratch.
Thank you Dougie, I love seeing your responses as they're always informative. However, it is my understanding that choosing the login to the command line does not automatically log you in, which is what I hope to achieve. Also I would still like to know what the difference components in those lines mean if you happen to know yourself. Thanks again!
Tue Sep 29, 2015 10:22 pm
hanniabu wrote:I have a few questions about auto login:
"man inittab" will tell you what the '1', '2345' and 'respawn' bits refer to. "man getty" will explain the rest of the line.
Wed Sep 30, 2015 5:19 pm
hanniabu wrote: Thank you Dougie, I love seeing your responses as they're always informative. However, it is my understanding that choosing the login to the command line does not automatically log you in, which is what I hope to achieve. Also I would still like to know what the difference components in those lines mean if you happen to know yourself. Thanks again!
Go and read the code in /usr/bin/raspi-config it's a bash shell script. You can hack that to get a command line autologin.
hanniabu
Wed Sep 30, 2015 6:55 pm
DougieLawson wrote: Go and read the code in /usr/bin/raspi-config it's a bash shell script. You can hack that to get a command line autologin.
I'll look into those, thanks for the leads guys!
