ccurran689
Reading a GPIO Switch in C language
Tue Sep 29, 2015 11:25 am
I know I must be doing something stupid here but I cant seem to find a solution, I am trying to have a simple switch in my circuit. I have made a simple switch programme to see where my issue is with no avail;
#include <stdio.h>
#include <wiringPi.h>
int main (void)
wiringPisetup () ;
pinMode (4, INPUT) ;
if (4==1) {
printf ("button pressed");
return 0;
I have one wire connected to one side of button going to gpio 23 ( WiringPi pin 4) and the other going to ground, nothing is happening.
rpdom
Re: Switch in C language
Tue Sep 29, 2015 11:33 am
ccurran689 wrote:
if (4==1) {
What are you trying to do here - test if 4 equals 1? Well, it won't ever (except in some really weird maths;) ).
Shouldn't you have something to read the pin value in there?
Something like
if ( didgitalRead(4) == 1 ) {
PeterO
Tue Sep 29, 2015 12:06 pm
Note that because there is a "switch" statement in the C language, your thread title is very ambiguous. !
PeterO
ame
Tue Sep 29, 2015 12:49 pm
PeterO wrote:Note that because there is a "switch" statement in the C language, your thread title is very ambiguous. !
PeterO
Did you report the post? There is an option to specify that the title is ambiguous or misleading.
ame
Tue Sep 29, 2015 12:54 pm
Anyway, back to the problem at hand.
OP, do you have a pullup attached to your button? If not, you should turn on the GPIO pullup in your code:
https://projects.drogon.net/raspberry-p ... functions/
Also, double-check the pin number against the physical pin.
PeterO
Tue Sep 29, 2015 12:55 pm
PeterO
Since rpdom had provided the answer I didn't think it was worth reporting but was worth pointing out it was ambiguous.
PeterO
GerardWassink
Tue Sep 29, 2015 1:01 pm
ame wrote:Anyway, back to the problem at hand.
Neither of these actions will make (4 == 1)... :D
And in any case, the value of the pin should first be read, otherwise you can test all you want and it will never be what you expect.
And remember:
"Computers do what you tell them, not necessarily what you expect..."
---------ooooO----- \\\\\|/// -----Oooo--------
Hacker on ELF-II, ZX80/1, Commodore 64, 8080, x86,
IBM 370 family mainframes
Machine code! Assembly! C good second.
Running Pi's with Hercules and S/370 OS's
-------------oooO-----------Oooo-------------
ame
Tue Sep 29, 2015 1:03 pm
And remember:
Yeah. My bad. Oh well.
PeterO
Tue Sep 29, 2015 1:24 pm
However both things are useful advice and need to be correct.
PeterO
ccurran689
Re: Reading a GPIO Switch in C language
Tue Sep 29, 2015 6:45 pm
Thanks very much got it all sorted, I had tried that before but must of mucked it up somehow. Doing an engineering project and have been left a bit blind for the code sorry about the silly questions!
Return to “C/C++”
