chris_c
[how to] enable long touch as right click
Fri Sep 25, 2015 1:02 pm
odds on you don't have an /etc/X11/xorg.conf if not its okay just to create this fragment...
/etc/X11/xorg.conf
Section "InputClass"
	Identifier "calibration"
	Driver "evdev"
	MatchProduct "FT5406 memory based driver"
	Option "EmulateThirdButton" "1"
	Option "EmulateThirdButtonTimeout" "750"
	Option "EmulateThirdButtonMoveThreshold" "30"
EndSection
(re)start X and you should find that a long press behaves like a right click, time to throw your mouse out?
Enjoy!
PeterO
Re: [how to] enable long touch as right click
Fri Sep 25, 2015 1:08 pm
Useful tip. 8-)
I remember the days of /etc/X11/xorg.conf :D
PeterO
gadgetoid
Tue Sep 29, 2015 10:39 am
Fantastically useful tip. Worked a treat on Raspbian Wheezy, but for some reason it doesn't work on Jessie.
xinput list-props 9
Shows the settings have taken effect, but the right menu is nowhere to be found!
PeterO
Tue Sep 29, 2015 10:46 am
gadgetoid wrote: but the right menu is nowhere to be found!
Does it still work with a mouse or has the right menu been removed ?
gadgetoid
Tue Sep 29, 2015 11:09 am
Haha! Nothing that drastic! There's still a right menu which works with the mouse.
chris_c
Tue Sep 29, 2015 11:39 am
I had a quick look at systemdOS but couldn't get it working nicely without systemd-udev so gave up... (happy with wheezy until a more up to date version of Linux is available)
You might want to check that the device name is still the same as in the config you might be seeing right button settings for a device that doesn't exist.
check that one of
xinput list --name-only
matches
in the config fragment.
MikeDunn
Tue Sep 29, 2015 9:03 pm
Hmmm - just added this to Jessie, but it seems not to work ?
Anyone got a working right-click on the touchscreen with Jessie ?
Mike
ulix
Wed Sep 30, 2015 2:09 pm
No,
The same here!
philkingmagpi
Wed Sep 30, 2015 4:25 pm
Same here – worked great on Wheezy but not Jessie. The device names do match (FT5406 memory based driver), so it doesn't seem to be that. Also, I noticed that when I do long-press in Jessie, a document icon appears under my finger.
eggster
Thu Oct 01, 2015 4:46 pm
Confirmed, this does not work with Jessie
ulix
Fri Oct 02, 2015 6:51 pm
is there no one which is more experienced and knows how to change it to right click? (When I do a long press, there appears a document on the mouse.)
cheers
dragonlost
Thu Oct 15, 2015 8:19 pm
Hello.
I have exactly the same problem on Raspbian jessie Official.
Nobody has a solution for the official touch screen?
I have more problem to solve it to operate the tablet raspberry
sandhan_pi_hacker
Fri Oct 16, 2015 5:54 am
I also tried these settings on raspbian jessie...but it doesn't seem to work.
JimmyN
Sun Oct 25, 2015 5:55 pm
I'm using Jessie and it doesn't work for me either.
Linux rpi2 4.1.11+ #822 PREEMPT Fri Oct 23 16:14:56 BST 2015 armv6l GNU/Linux
And when I try "xinput list --name-only" it gives me a command not found. Using "locate" I have no xinput anywhere, though I do have lxinput, but that only seems to change the mouse settings (speed, acceleration, etc)
What am I missing? From the previous posts it seems I should still have xinput with Jessie.
lilgman
Wed Nov 04, 2015 2:39 pm
@JimmyN It seems that xinput isn't installed by default. You can install it with
sudo apt-get install xinput
I think this may be a Debian Jessie problem. See http://forums.debian.net/viewtopic.php?f=7&t=115567 and http://superuser.com/questions/992917/t ... oesnt-work
If anyone figures out a solution, I would love to know about it!
pumpkinpi
Mon Nov 23, 2015 3:07 am
This is a really key thing for me too. Would love to get it working.
PPi
pdream
Wed Dec 02, 2015 2:42 pm
Thanks , it works with my raspbian wheezy !
BBMECH7
Wed Jan 13, 2016 12:44 pm
So i can confirm also not getting right click option in Jessie, I noticed something though
xinput list-props 9
did not work for me.
xinput list
showed my touch screen was listed as #8 so i changed the 9 to an 8 and i got a list of properties.
xinput was also not installed as default in Jessie, an easy fix.
xev
Showed the I never got any thing other than a 'button 1' being pressed no 'button 3' ever.
I was also able to use:
xinput set-prop
To change the various options for the 3rd button and see the changes by doing 'list-props' but again no change in 'xev' showing anything other than button 1. :?
The changes showed in list-props but does that mean that are effective now or they need a restart of x?
To further add to my confusion I tried to burn a fresh install of the latest Wheezy from here and it doesn't initialize the screen on power up like Jessie did. Is there something more that needs done to Wheezy?
BBMECH7
Fri Jan 15, 2016 12:36 am
ok so i will answer my own questions for the sake of others.
wheezy needs apt-get update and upgrade to utilize the screen.
a keyboard called florence (i think.... might be spelled differently.) works well customizable and can be hidden easily.
by installing xinput and using the commands i mentioned before you can make live changes to the touch screens behavior including the right click long press.
EDIT: changes made by using
xinput set-prop
seem to only be temporary and will need ot be saved as mentioned above.
cpostier
Mon Jan 18, 2016 5:41 pm
Ugh, I'm chmod-ing that X11 directory but I cant write any file to it :( I am a bit new to this, tried to vi create the file, no luck either. using filezilla and ssh connect to it tried creating locally then drag it over... stubborn pi
Any suggestions?
UPDATE: I got it, sorry, sudo chmod 777 "X11"
stutteringp0et
Thu Jan 21, 2016 6:33 am
I hate to be another "me too" - but it's still not working in Jesse
AiGreek
Thu Jan 21, 2016 6:36 am
I use a touchscreen from chalk-elec.com and since the last rpi-update, the long press is working
isntitknoying
Sun Jan 24, 2016 12:14 am
AiGreek wrote:I use a touchscreen from chalk-elec.com and since the last rpi-update, the long press is working
I have one of their touchscreens as well...do you use the same driver and matchproduct lines?
Sun Jan 24, 2016 4:16 pm
I added the config (from posting.php?mode=reply&f=108&t=121602#pr820611) as new file /usr/share/X11/xorg.conf.d/20-touchscreen.conf
/var/log/Xorg.0.log shows
[    15.151] (II) Using input driver 'evdev' for 'FT5406 memory based driver'
[    15.152] (**) FT5406 memory based driver: always reports core events
[    15.152] (**) evdev: FT5406 memory based driver: Device: "/dev/input/event2"
[    15.152] (--) evdev: FT5406 memory based driver: Vendor 0 Product 0
[    15.152] (--) evdev: FT5406 memory based driver: Found absolute axes
[    15.152] (--) evdev: FT5406 memory based driver: Found absolute multitouch axes
[    15.152] (II) evdev: FT5406 memory based driver: No buttons found, faking one.
[    15.153] (--) evdev: FT5406 memory based driver: Found x and y absolute axes
[    15.153] (--) evdev: FT5406 memory based driver: Found absolute touchscreen
[    15.153] (II) evdev: FT5406 memory based driver: Configuring as touchscreen
[    15.153] (**) Option "EmulateThirdButton" "1"
[    15.153] (**) Option "EmulateThirdButtonTimeout" "750"
[    15.153] (**) Option "EmulateThirdButtonMoveThreshold" "30"
[    15.153] (**) evdev: FT5406 memory based driver: YAxisMapping: buttons 4 and 5
[    15.153] (**) evdev: FT5406 memory based driver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
so it's been read.
xinput list-props 8 gets this
Device 'FT5406 memory based driver':
        Device Enabled (116):   1
        Coordinate Transformation Matrix (117): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
        Device Accel Profile (244):     0
        Device Accel Constant Deceleration (245):       1.000000
        Device Accel Adaptive Deceleration (246):       1.000000
        Device Accel Velocity Scaling (247):    10.000000
        Device Product ID (237):        0, 0
        Device Node (238):      "/dev/input/event2"
        Evdev Axis Inversion (248):     0, 0
        Evdev Axis Calibration (249):   <no items>
        Evdev Axes Swap (250):  0
        Axis Labels (251):      "Abs MT Position X" (242), "Abs MT Position Y" (243), "None" (0), "None" (0)
        Button Labels (252):    "Button Unknown" (239), "Button Unknown" (239), "Button Unknown" (239), "Button Wheel Up" (122), "Button Wheel Down" (123)
        Evdev Scrolling Distance (253): 0, 0, 0
        Evdev Middle Button Emulation (254):    0
        Evdev Middle Button Timeout (255):      50
        Evdev Third Button Emulation (256):     1
        Evdev Third Button Emulation Timeout (257):     750
        Evdev Third Button Emulation Button (258):      3
        Evdev Third Button Emulation Threshold (259):   30
        Evdev Wheel Emulation (260):    0
        Evdev Wheel Emulation Axes (261):       0, 0, 4, 5
        Evdev Wheel Emulation Inertia (262):    10
        Evdev Wheel Emulation Timeout (263):    200
        Evdev Wheel Emulation Button (264):     4
        Evdev Drag Lock Buttons (265):  0
But I can't find any part of the GUI that I'd expect to react to a right click. But that may be simply because I so very rarely do anything with the GUI or I'm an idiot, or it doesn't work.
a human
Mon Feb 01, 2016 1:36 pm
Does this Work on the rasbian stretch beta?
