kusti8
Re: Guide: Chromium 49 on Raspbian Jessie
Wed May 25, 2016 11:05 am
gkreidl wrote:Solution:
add
CHROMIUM_FLAGS="${CHROMIUM_FLAGS} --disable-gpu"
to
/etc/chromium-browser/customizations/00-example
or modify /etc/chromium-browser/default
CHROMIUM_FLAGS="--disable-gpu"
Thanks for this. I'll patch the deb.
Ben_is_best
Wed May 25, 2016 12:18 pm
add
to
What happens if you do both?
gkreidl
Wed May 25, 2016 1:03 pm
add
to
You'll add the option twice.
Minimal Kiosk Browser (kweb)
saharhostnile
Wed May 25, 2016 8:52 pm
I'll look into it when I have time. I didn't test it with other packages, could you name the ones which are having trouble? You may have have to update those to jessie as well.
kusti8
Wed May 25, 2016 10:05 pm
saharhostnile wrote:I'll look into it when I have time. I didn't test it with other packages, could you name the ones which are having trouble? You may have have to update those to jessie as well.
kusti8
Re: Guide: Chromium 50 on Raspbian Jessie
Fri May 27, 2016 3:34 pm
Now updated for v50!!!
Update using:
sudo apt-get update
sudo apt-get dist-upgrade
Enjoy! :)
gkreidl
Fri May 27, 2016 3:45 pm
kusti8 wrote:Now updated for v50!!!
Enjoy! :)
I get an error with apt-get update:
Fehlschlag beim Holen von http://dl.bintray.com/kusti8/chromium-r ... f/Packages 404 Not Found [IP: 159.122.18.156 80]
kusti8
Fri May 27, 2016 3:48 pm
Enjoy! :)
Try again. When trying to download packages right when it is updating can result in some things not found. I just tried it and it worked.
sudo apt-get update
Dis93
Fri May 27, 2016 3:56 pm
W: Failed to fetch http://dl.bintray.com/kusti8/chromium-r ... f/Packages 404 Not Found [IP: 5.153.35.248 80]
I tried it a few times kusti8. I got this error with that IP address rather than the 159.x.x.x one
EDIT: working on fifth attempt
kusti8
Fri May 27, 2016 3:59 pm
Dis93 wrote:W: Failed to fetch http://dl.bintray.com/kusti8/chromium-r ... f/Packages 404 Not Found [IP: 5.153.35.248 80]
That's weird. I just did a apt-get update and it worked fine. Try waiting five minutes and try again. When I go to http://dl.bintray.com/kusti8/chromium-r ... ary-armhf/ I can find Packages.
Edit: Just saw your edit, nice.
gkreidl
Fri May 27, 2016 4:04 pm
Now it's working for me, too.
ChickenPillow
Fri May 27, 2016 4:15 pm
Well basically I copy and pasted the code into terminal, and after a while it just stays on 'Unpacking nodered (0.13.4-1) over (0.13.4) ...' any ideas on how to work it?
kusti8
Fri May 27, 2016 4:16 pm
ChickenPillow wrote:Well basically I copy and pasted the code into terminal, and after a while it just stays on 'Unpacking nodered (0.13.4-1) over (0.13.4) ...' any ideas on how to work it?
That's a problem with apt and not Chromium at all, but:
sudo apt-get purge nodered
Should fix it.
kusti8
Fri May 27, 2016 4:18 pm
It seems like an ongoing problem. I've just run into it too:
viewtopic.php?f=28&t=149361&p=982507&hi ... ed#p982507
Fri May 27, 2016 5:40 pm
kusti8,
The sudo apt-get update/sudo apt-get dist-upgrade thing has completed fine here. I have no chance to test the resulting installation as I have no screen attached just now.
Thanks for the tremendous effort.
kusti8
Fri May 27, 2016 5:44 pm
Heater wrote:kusti8,
jdenec123
Sat May 28, 2016 6:02 am
I am going to preface this by saying I am very new to this.
I am trying to install Chromium in OctoPi in order to use TouchUI on a touchscreen through the Raspberry Pi. I am using a guide created by BillyBlaze that references your article in order to install Chromium.
No matter how I type it, I cannot get the second command...
sudo apt-key add -echo "deb http://dl.bintray.com/kusti8/chromium-rpi jessie main"
...to do anything. It is giving me a "conflicting commands" error.
The command before creates a ton of seemingly random characters. Is that what it's supposed to do?
Thanks for your help!
kusti8
Sat May 28, 2016 1:41 pm
You're mixing up the commands. They are there in a specific order with different lines for a reason. Just copy and paste it into the terminal and it will all work. Now I would check that you don't have anything weird in sources.list:
sudo nano /etc/apt/sources.list
jdenec123
Sat May 28, 2016 4:09 pm
kusti8 wrote:You're mixing up the commands. They are there in a specific order with different lines for a reason. Just copy and paste it into the terminal and it will all work. Now I would check that you don't have anything weird in sources.list:
Wow. I feel like an idiot now. I thought "|" meant a new line. Like a said, I'm new to this.
Thanks again! Worked perfectly
Kratos
Sat May 28, 2016 7:36 pm
After browsing the web for a few days on it (v50), I must say it eats a ton of RAM up. 3 tabs of the forums struggle to stay responsive. I do have 256 MB of RAM set for the GPU, so that may affect it...
Kratos
I have posted mostly with a Pi 2 running either Ubuntu MATE, or Raspbian.
kusti8
Sat May 28, 2016 7:37 pm
Kratos wrote:After browsing the web for a few days on it (v50), I must say it eats a ton of RAM up. 3 tabs of the forums struggle to stay responsive. I do have 256 MB of RAM set for the GPU, so that may affect it...
Kratos
Well that's webpages and webbrowsers for you. 256 MB is a lot though , you don't really need that much.
Kratos
Sat May 28, 2016 10:01 pm
Considering that Chromium 50 is running on a PC the size of my wallet (a bit thinner than my wallet fortunately) I am not too concerned about lagginess. I appreciate all the time you have poured into this!
Kratos
torekk
Contact: ICQ
Sun May 29, 2016 12:32 am
I had problems with version 49 and 256mb GPU ram as well, since I lowered that to 128mb it isn't as worse.
Also thanks a lot for your work kusti8, really appreciate it. Only got my Pi3 like 2 weeks ago as a temporary desktop replacement and in my opinion it's just amazing that I can even watch YouTube in fullscreen* on this small thing.
*Well it doesn't work for every video, mostly older ones being a problem, but I guess that's due to missing codecs?
cjan
Sun May 29, 2016 12:34 am
/etc/chromium-browser/default can not add 2 options? flashplugin was gone.
kusti8
Sun May 29, 2016 1:02 am
cjan wrote:/etc/chromium-browser/default can not add 2 options? flashplugin was gone.
Did you add a space? Can you paste the file?
