Does anyone know links for the schematics for the Raspberry Pi 2, the B+ (complete V1.2, not the 1-pager), and the A+ modules?
Mechanical drawings for the B+ and A+ would be appreciated also.
I thought it had been said that it was because Eben had got fed up of people asking for things then not appreciating them when delivered, complaining it wasn't enough, so nothing to do with Element14/RS. The other long running reason has been because the Foundation has to protect its IP to protect its revenue stream.mahjongg wrote:Not publishing further schematics is probably enforced by Lawyer's from Element14/RS, so its no good asking for them.
The above is a case in point - the Foundation goes to some lengths to improve the situation for people, and all they get back is a load of 'not good enough' Same thing happened when the initial release was made of all the ARM side code that was previously closed source. Eben spent weeks getting the permissions to release that, with lots of haggling with Broadcom lawyers etc. And what did he get? Abuse because it wasn't enough. He decided there and then, screw you. If you are not going to even say thanks then why bother doing it. There are better things for him to spend his time on.
And the results are what you see before you.
Sad? Maybe, but it's his project, which he has spent an awful lot of time on, and if he wants to eject his toys from the baby carrying device, that up to him!
Me neither. Perhaps someone will one day come out with a straight and honest answer and tell us what it is.mahjongg wrote:I'm not convinced its the real reason
That seems hard to believe when we are told that the latest schematics would be virtually identical to the schematics which have been released. It's hard to imagine what IP or confidentiality were being protected.DougieLawson wrote:The most likely answer is commercial confidentiality and non-disclosure.
