In order to do this, i installed these packages in the system:
libegl1-mesa-dev - free implementation of the EGL API -- development files
libgegl-dev - Generic Graphics Library (development files)
libgles2-mesa-dev - free implementation of the OpenGL|ES 2.x API -- development files
libgl1-mesa-swx11-dev - free implementation of the OpenGL API -- development files
#define _IRR_COMPILE_WITH_OPENGL_
#define _IRR_COMPILE_WITH_OGLES1_
#define _IRR_COMPILE_WITH_OGLES2_
#define _IRR_COMPILE_WITH_EGL_MANAGER_
#define _IRR_COMPILE_WITH_GLX_MANAGER_
#define _IRR_COMPILE_WITH_X11_DEVICE_
make -j 4
cmake . -DRUN_IN_PLACE=TRUE -DENABLE_GLES=1 -DEGL_INCLUDE_DIR=/opt/vc/include/EGL -DEGL_LIBRARY=/usr/lib/arm-linux-gnueabihf/libEGL.so -DOPENGLES2_INCLUDE_DIR=/opt/vc/include/GLES2 -DOPENGLES2_LIBRARY=/usr/lib/arm-linux-gnueabihf/libGLESv2.so -DFREETYPE_INCLUDE_DIR_freetype2=/usr/include/freetype2 -DFREETYPE_INCLUDE_DIR_ft2build=/usr/include/freetype2 -DFREETYPE_LIBRARY=/usr/lib/arm-linux-gnueabihf/libfreetype.a -DIRRLICHT_SOURCE_DIR=/irrlicht/ogl-es/source/Irrlicht
make -j 4
-lEGL -lGLESv2 -L/opt/vc/lib
finally, in order to select ogles2 I modify minetest.conf by adding:
video_driver = ogles2
It seems that with these changes OpenGL ES 2Driver is initialized, or at least, I get this log:
INFO[Main]: Irrlicht: Creating X window...
INFO[Main]: Irrlicht: Using plain X visual
VERBOSE[Main]: Irrlicht: Visual chosen: : 33
VERBOSE[Main]: Irrlicht: Window Location: 1,30
Window Dimensions 800 x 585
Bit depth : 16
INFO[Main]: Irrlicht: EGL version: 1.400000
VERBOSE[Main]: Irrlicht: CirrDeviceLinux.cpp EDT_OGLES2 - context initialized.
VERBOSE[Main]: Irrlicht: config chosen
VERBOSE[Main]: Irrlicht: surface created
ERROR[Main]: Irrlicht: Creating EGL context for OpenGLESVersion: : 2
ERROR[Main]: Irrlicht: ContextAttrib[1]: : 2
VERBOSE[Main]: Irrlicht: EGL context created with OpenGLESVersion: : 2
ERROR[Main]: Irrlicht: Activating Context EGL
ERROR[Main]: Irrlicht: Activated Context EGL
INFO[Main]: Irrlicht: Using renderer:
ERROR[Main]: Irrlicht: COGLES2Driver - genericDriverInit Done
VERBOSE[Main]: Irrlicht: CirrDeviceLinux.cpp EDT_OGLES2 - Created OGLES2 Driver.
VERBOSE[Main]: Irrlicht: CirrDeviceLinux.cpp - Created Driver.
VERBOSE[Main]: Irrlicht: CirrDeviceLinux.cpp - Created Driver OK.
VERBOSE[Main]: Irrlicht: CirrDeviceLinux.cpp - createInputContext.
VERBOSE[Main]: Irrlicht: CirrDeviceLinux.cpp - createGUIAndScene.
While debugging this error I realized that COGLES2ExtensionHandler::initExtensions was not doing very well, since:
glGetIntegerv(GL_MAX_TEXTURE_SIZE, &val);
MaxTextureSize=static_cast<u32>(val);
So, I added more debug and find out that glGetFloatv, glGetIntegerv and glGetString function calls at initExtensions were failing
Irrlicht: COGLES2ExtensionHandler::initExtensions:
INFO[Main]: Irrlicht: GL_AMD_compressed_3DC_texture: false
INFO[Main]: Irrlicht: GL_OES_blend_equation_separate: false
INFO[Main]: Irrlicht: GL_OES_blend_func_separate: false
INFO[Main]: Irrlicht: GL_OES_blend_subtract: false
INFO[Main]: Irrlicht: GL_OES_byte_coordinates: false
INFO[Main]: Irrlicht: GL_OES_compressed_ETC1_RGB8_texture: false
INFO[Main]: Irrlicht: GL_OES_compressed_paletted_texture: false
INFO[Main]: Irrlicht: GL_OES_depth24: false
INFO[Main]: Irrlicht: GL_OES_depth32: false
INFO[Main]: Irrlicht: GL_OES_depth_texture: false
INFO[Main]: Irrlicht: GL_OES_draw_texture: false
INFO[Main]: Irrlicht: GL_OES_EGL_image: false
INFO[Main]: Irrlicht: GL_OES_EGL_image_external: false
INFO[Main]: Irrlicht: GL_OES_EGL_sync: false
INFO[Main]: Irrlicht: GL_OES_element_index_uint: false
INFO[Main]: Irrlicht: GL_OES_extended_matrix_palette: false
INFO[Main]: Irrlicht: GL_OES_fbo_render_mipmap: false
INFO[Main]: Irrlicht: GL_OES_fixed_point: false
INFO[Main]: Irrlicht: GL_OES_fragment_precision_high: false
INFO[Main]: Irrlicht: GL_OES_framebuffer_object: false
INFO[Main]: Irrlicht: GL_OES_get_program_binary: false
INFO[Main]: Irrlicht: GL_OES_mapbuffer: false
INFO[Main]: Irrlicht: GL_OES_matrix_get: false
INFO[Main]: Irrlicht: GL_OES_matrix_palette: false
INFO[Main]: Irrlicht: GL_OES_packed_depth_stencil: false
INFO[Main]: Irrlicht: GL_OES_point_size_array: false
INFO[Main]: Irrlicht: GL_OES_point_sprite: false
INFO[Main]: Irrlicht: GL_OES_query_matrix: false
INFO[Main]: Irrlicht: GL_OES_read_format: false
INFO[Main]: Irrlicht: GL_OES_required_internalformat: false
INFO[Main]: Irrlicht: GL_OES_rgb8_rgba8: false
INFO[Main]: Irrlicht: GL_OES_single_precision: false
INFO[Main]: Irrlicht: GL_OES_standard_derivatives: false
INFO[Main]: Irrlicht: GL_OES_stencil1: false
INFO[Main]: Irrlicht: GL_OES_stencil4: false
INFO[Main]: Irrlicht: GL_OES_stencil8: false
INFO[Main]: Irrlicht: GL_OES_stencil_wrap: false
INFO[Main]: Irrlicht: GL_OES_surfaceless_context: false
INFO[Main]: Irrlicht: GL_OES_texture_3D: false
INFO[Main]: Irrlicht: GL_OES_texture_cube_map: false
INFO[Main]: Irrlicht: GL_OES_texture_env_crossbar: false
INFO[Main]: Irrlicht: GL_OES_texture_float: false
INFO[Main]: Irrlicht: GL_OES_texture_float_linear: false
INFO[Main]: Irrlicht: GL_OES_texture_half_float: false
INFO[Main]: Irrlicht: GL_OES_texture_half_float_linear: false
INFO[Main]: Irrlicht: GL_OES_texture_mirrored_repeat: false
INFO[Main]: Irrlicht: GL_OES_texture_npot: false
INFO[Main]: Irrlicht: GL_OES_vertex_array_object: false
INFO[Main]: Irrlicht: GL_OES_vertex_half_float: false
INFO[Main]: Irrlicht: GL_OES_vertex_type_10_10_10_2: false
INFO[Main]: Irrlicht: GL_QCOM_alpha_test: false
INFO[Main]: Irrlicht: GL_QCOM_binning_control: false
INFO[Main]: Irrlicht: GL_QCOM_driver_control: false
INFO[Main]: Irrlicht: GL_QCOM_extended_get: false
INFO[Main]: Irrlicht: GL_QCOM_extended_get2: false
INFO[Main]: Irrlicht: GL_QCOM_performance_monitor_global_mode: false
INFO[Main]: Irrlicht: GL_QCOM_tiled_rendering: false
INFO[Main]: Irrlicht: GL_QCOM_writeonly_rendering: false
INFO[Main]: Irrlicht: GL_SUN_multi_draw_arrays: false
INFO[Main]: Irrlicht: GL_VIV_shader_binary: false
VERBOSE[Main]: Irrlicht: COGLES2ExtensionHandler::initExtensions - GL_MAX_TEXTURE_IMAGE_UNITS = 0
VERBOSE[Main]: Irrlicht: COGLES2ExtensionHandler::initExtensions - GL_MAX_TEXTURE_SIZE = 0
VERBOSE[Main]: Irrlicht: COGLES2ExtensionHandler::initExtensions - GL_ALIASED_LINE_WIDTH_RANGE = 0.000000
VERBOSE[Main]: Irrlicht: COGLES2ExtensionHandler::initExtensions - GL_ALIASED_POINT_SIZE_RANGE = 0.000000
Minetest Android client (with Irrlicht ogl es 1.9.0) works perfectly, and so it should work for raspberry pi
Is anybody up to take the challenge? If not... any tips on how I can continue getting Irrlicht (OpenGL ES) to work with Raspberry pi ?
