JaredC79
Wifi Direct
Tue Sep 15, 2015 6:22 pm
Is it possible to control OSMC via WIFI direct similar to the roku? I have the Wifi dongle, Rasp connected via LAN. If so how is this enabled? I also have a USB IR receiver that i may eventually stick on a gpio and connect via 3.5mm tr wire but i guess using the xbox IR codes would be the best should wifi direct not be an option. I also have an Asus BT dongle and my universal can connect via bluetooth to a PS3. Should i choose that option - what do i need to install to set it up? I already have and installed Bluez
Return to “Media centres”
