pcasebere
external hdd
Thu Sep 10, 2015 11:33 am
I'm trying to mount my external hard drive (wd my passport ultra) in terminal on my rpi2; I've got ntfs-3g installed, but when I fdisk -l I don't see the hard drive.. at all. please help
RaTTuS
Contact: Twitter YouTube
Re: external hdd
Thu Sep 10, 2015 12:00 pm
sudo fdisk -l
also see what
/var/log/syslog
says when you plug it in
Covfefe
Dorian_WD
Re: external hdd
Thu Sep 10, 2015 12:01 pm
Hey pcasebere,
I'm sorry to hear about your issue. Is the drive working properly when connected to a computer and you are experiencing this only when plugging it into the Raspberry Pi?
If this is the case, then you can try the following steps: http://www.instructables.com/id/Mountin ... -Pi/#step1
I hope this will help you.
Ragards
kusti8
Re: external hdd
Thu Sep 10, 2015 12:09 pm
It may not be getting enough power. Is the hard drive spinning up?
There are 10 types of people: those who understand binary and those who don't.
pcasebere
Re: external hdd
Thu Sep 10, 2015 12:13 pm
Dorian_WD wrote:Hey pcasebere,
Ragards
Yes, the drive works fine with OSX, however when I plug in to RPI2 the drive starts a periodic clicking, and nothing -haven't tried replies as of yet, 'though.
kusti8
Re: external hdd
Thu Sep 10, 2015 12:15 pm
You may not be getting enough power.
Add max_usb_current=1
To config.txt and try again.
pcasebere
Re: external hdd
Sat Sep 19, 2015 5:17 pm
In the end it was the classic "not 'nough power;" got a powered hub, and now it's working as it should.
klricks
Re: external hdd
Sat Sep 19, 2015 8:29 pm
pcasebere wrote:In the end it was the classic "not 'nough power;" got a powered hub, and now it's working as it should.
Most drives will work on B+ and 2B models without a HUB if you do the config change suggested by kusti8.
