dom
Re: Safe Mode
Tue Dec 04, 2012 5:29 pm
plugh wrote:Are you talking about putting something into the mainstream firmware release? (imho fwiw, I'd say remove the current 'pretend' hack from the firmware and just release a fix-it app.)
Anyway... Do you have "bad" samples to test against (it IS a OneTP), or are you looking for a volunteer?
Yes. It will be done from an updated start.elf.
The code for programming the board rev is already in place (and well tested). Currently you can program your board rev with:
program_board_rev=<board_rev>
in config.txt. But it only lets you if you currently have a zero board rev.
I'll change it so you can also program the board_rev if it currently differs from the reported board rev. I should push that out tonight.
dom
Re: Safe Mode
Wed Dec 05, 2012 6:19 pm
@plugh
Latest "next" tree firmware can update your board revision. Update with:
sudo rpi-update c6b0066396723a86f390f8330a679bbce8e99b9b
(you may need to "sudo rpi-update" first).
Then add:
program_board_rev=15
to config.txt and reboot. After that, safe mode should work as expected, and:
vcgencmd otp_dump |grep 30:
should now be 15.
plugh
Re: Safe Mode
Wed Dec 05, 2012 7:38 pm
The deed is done; OTP rev is now 0xF.
And vanilla 10-28 raspbian kit now boots kernel_emergency.img with GPIO3 (rev2 P1-5) pulled down.
Thanks!
sdjf
Re: Safe Mode
Thu Dec 06, 2012 6:39 am
The instruction to "Short Jumpers 5&6" in the wiki needs to be expanded to make sense to folks who have no clue what that means. It leaves me guessing that it means to connect the pins?
http://elinux.org/RPI_safe_mode
Also, does this apply to Arch as well, or to the Next firmware that Pepedog made available to Raspberry Pi Arch Linux users?
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
bgirardot
Re: Safe Mode
Fri Dec 28, 2012 6:57 pm
sdjf wrote:The instruction to "Short Jumpers 5&6" in the wiki needs to be expanded to make sense to folks who have no clue what that means. It leaves me guessing that it means to connect the pins?
I edited that wiki page and added a photo. I think it clarifies what to do a fair amount.
Schuitz
Re: Safe Mode
Sun Jan 27, 2013 1:30 pm
I just wanted to add that I got into trouble and needed the emergency kernel as described. I also have the incorrect OTP as described.
With a set of sharp tweezers and good eyesight, you can, with care, pull s5 pin 13 to ground by using tweezers to short it to pin 10. A third hand is useful to power on the board, but not essential if you are steady.
Strictly speaking, hitting adjacent pins cam_clk or cam_gpio is probably not a great idea if they are set up as push-pull outputs early in the boot sequence, but is unlikely to be catastrophic. But don't hold me to it. You don't have to dwell there long, as the alternate kernel should come up immediately.
Best to have your second cup of coffee after doing this maneuver. But then, you're here because you're in the soup, right? If it weren't dicey it wouldn't be fun :mrgreen: .
Schuitz
Re: Safe Mode
Sun Jan 27, 2013 3:44 pm
...aaaand a guy should read to the end of the thread before posting. However, if you're like me and get stuck before you have updated to the latest and greatest, you still have to pull a move on S5. Or, if you're like me and tack-soldered some wires onto P1 pin 6 for an IR receiver, no jumper for you.
I will add that it's simpler just to short S5 pin 13 to the HDMI shield.
In my case, once I was in, I had to mount -t ext4 my root partition because I blew an fstab entry.
moreins
Re: Safe Mode
Thu Jan 31, 2013 2:45 am
hello
I configured a daemon that starts at runlevel 2. i messed up and ended up with a hung boot process.
i got to safe mode on my raspi but im struggling when mounting the mmc so i can fix this.
i tried
mkdir /mnt
mount /dev/mmcblk0p2 /mnt
and i get
mount: mounting /dev/mmcblk0p2 on /mnt failed: No such file or directory
can you kindly provide any ideas on how to fix this?
thanks
moreins
Re: Safe Mode
Thu Jan 31, 2013 3:30 am
moreins wrote:hello
i tried
mkdir /mnt
and i get
thanks
update: this worked for me better
http://raspberrypi.org/phpBB3//viewtopi ... 06#p163706
rod_gilchrist
Re: Safe Mode
Thu Oct 10, 2013 1:50 am
To ask the same question again, how do you mount partition 2 of the SD card in safe mode?
by dom » Wed Aug 15, 2012 9:33 am
thektalin wrote:
Hello,how do i mount /dev/mmcblk0p2 in safe mode? because if i type: df, i can find it .
If /mnt doesn't exist then "mkdir /mnt" first.
This is what happens from safe mode:
  • # ls -ld /mnt
    drwxr-xr-x 2 root root 0 Sep 19 2013 /mnt
    # ls -l /dev/mmcblk0p2
    brw-rw---- 1 root root 179, 2 Jan 1 00:00 /dev/mmcblk0p2
    # mount /dev/mmcblk0p2 /mnt
    mount: mounting /dev/mmcblk0p2 on /mnt failed: Invalid argument
rod_gilchrist
Re: Safe Mode
Fri Oct 11, 2013 3:22 am
To answer my own question, you don't mount partition 2 of the SD card when you are using NOOBS 1.3.
Partition 2 is the device for the entire disk. Presumably it used to be something useful to mount but it
no longer makes sense to do so.
What I was trying to do was to use safe mode to restore the old kernel after I installed one that didn't work.
See below for the answer to that question.
by rod_gilchrist » Wed Oct 09, 2013 9:50 pm
In NOOBS 1.3 safe mode with Rasbian installed, an fdisk -l gives the following:
        Device Boot      Start         End      Blocks   Id  System
/dev/mmcblk0p1            8192     2505859     1248834    e  W95 FAT16 (LBA)
/dev/mmcblk0p2         2506752    15663103     6578176   85  Linux extended
/dev/mmcblk0p3        15663104    15728639       32768   83  Linux
/dev/mmcblk0p5         2514944     2637823       61440    c  W95 FAT32 (LBA)
/dev/mmcblk0p6         2646016    15663103     6508544   83  Linux
The partitions are:
/dev/mmcblk0p1 - this partition is the recovery file system containing the system images.
/dev/mmcblk0p5 - this partition is mounted as /boot when in normal operation of Raspian.
/dev/mmcblk0p6 - this partition is the / filesystem when in normal operation.
dom's answer above works fine for mounting any of these three file systems in safe mode or on another linux machine (e.g.)
mount /dev/mmcblk0p5 /mnt
Another useful and interesting answer is that if you plug the SD card into a Mac, partition 1 and 5 show up as
disks called RECOVERY and BOOT respectively.
Tyguy7
Re: Safe Mode
Mon Dec 16, 2013 1:50 am
Unfortunately, doing this fried my Pi. I made sure to use a jumper that hasn't been in a computer for many years, so it definitely carried no charge. I am not happy at all.
texy
Re: Safe Mode
Mon Dec 16, 2013 7:36 am
A jumper doesn't carry any charge - it is just a short piece of wire/metal :o
Texy
gmc
Re: Safe Mode
Wed Dec 18, 2013 9:04 pm
Great feature - this will really come in handy.
Douglas6
Re: Safe Mode
Fri Jan 03, 2014 6:09 pm
Well, this saved my cookies when i ended up with a 'halt' command in my /etc/rc.local (don't ask). Cool feature, thanks!
dom
Re: Safe Mode
Tue Mar 18, 2014 6:20 pm
This feature is removed from default firmware as of 18th March 2014. NOOBS still supports a safe mode, using the same gpio pins.
cleverca22
Re: Safe Mode
Thu Mar 20, 2014 3:51 am
why was it removed?, could a config.txt parameter be used to turn it back on?
dom
Re: Safe Mode
Thu Mar 20, 2014 4:15 pm
cleverca22 wrote:why was it removed?, could a config.txt parameter be used to turn it back on?
It was an order from above. I think the view was that no one used it, and it was occasionally triggered accidently (when interfacing with hardware like Gert board).
It requires maintaining an additional kernel build (kernel_emergency.img), and the extra sdcard space / download time when updating.
(personally I'd have prefered to keep it, as I use it occasionally).
Douglas6
Re: Safe Mode
Thu Mar 20, 2014 5:16 pm
Awwwww. I've used it (see my post 3 or 4 back). There are work-arounds, and I can see the confusion it might cause, but personally I would have kept it too. :)
Re: Safe Mode
Thu Mar 20, 2014 5:31 pm
I would have kept it too, as it provided a good environment to make backup SD cards with just a USB card reader.
I agree that the number of false activations were becoming a bit of a problem though, but I'd probably make the "ignore_safe_mode" the default.
I can see that building a special kernel just for this (rarely used) mode isn't really justified.
cleverca22
Re: Safe Mode
Fri Mar 21, 2014 12:33 am
it could be modified to only work if a config.txt entry enables it?
the config.txt could also select which gpio triggers safemode, so if you dont want it, just dont enable it
if the gertboard causes problems with the current pin and you have another pin that is safe and want it, just change it in config.txt
i had thought about using safe mode to boot into an OS menu, but letting start.elf run the 'selected' OS directly when your not holding that button
the kernel_emergency.img would rename kernel.img to match your choice, and then it would run the last item with zero middleman
moak
Re: Safe Mode
Wed Feb 25, 2015 8:25 pm
I short pins 5&6, then reset and the machine still boots and hangs. It freezes at
info loading kernel module waveshare32b
FATAL: module waveshare32b not found
info loading kernel module ads7846_device.
14.840741 ads7846_device: Deleting spi0.1
I would have thought this wouldn't load if booting in to safe mode? Hence me asking, shorting pins 5&6 don't seem to allow it to boot in to safe mode :(
olddeccie
Re: Safe Mode
Fri Feb 27, 2015 11:06 pm
Hi...
anything to do with this?
by dom » Tue Mar 18, 2014 6:20 pm
moak
Re: Safe Mode
Sat Feb 28, 2015 11:25 am
Perhaps, I'm not using NOOBS, so maybe...
I ended up booting off another card, mounted the one that wouldn't boot and referenced out the new lines that was preventing it from booting.
mkj
Re: Safe Mode
Fri Apr 10, 2015 12:19 pm
I wanted to keep using safe mode so I've written a little program to achieve the same thing. Rather than booting two kernels it boots between two different partitions. It works for me but haven't tested much - hope it might be useful for someone.
https://github.com/mkj/rpi-flipflop
Return to “Advanced users”
