wandiligong
HDMI video and AV audio
Sat Sep 05, 2015 12:19 pm
I run Kodi with OpenElec on my Pi model B. Music library on USB memory stick and controlled by Yatse on my tablet via WiFi. Use AV to connect audio to stereo and video to TV when occassionally required. Very happy with this.
However I have recently been tracking down the cause of a hum in the stereo and found caused by AV video connection to TV. Some sort of ground loop I imagine. I can overcome by disconnecting AV to TV (mostly run headless with Yatse) but I thought a permanent solution might be to use HDMI for video (which may stop the hum) to TV and retain AV connection to stereo.
Is this possible?
If so how can I set it up?
Re: HDMI video and AV audio
Sun Sep 06, 2015 1:30 pm
wandiligong wrote:I run Kodi with OpenElec on my Pi model B. Music library on USB memory stick and controlled by Yatse on my tablet via WiFi. Use AV to connect audio to stereo and video to TV when occassionally required. Very happy with this.
Is this possible?
Why not use HDMi for both Video and Audio :?:
Though yes on a B+ and later you can just use a standard audio cable from the 4TRRS Composite / Audio Port ;)
http://www.raspberrypi-spy.co.uk/2014/0 ... video-jack
wandiligong
Mon Sep 07, 2015 9:06 am
Thank you for response
I want HDMI to video (use as monitor occassionally) and audio via AV/RCA plugs to stereo (the main reason for Kodi).
I thought using a HDMI cable would default audio to HDMI also, however I have now found info in intro files on how to edit config file which should enable me to do what I want. I will experiment with this when I have time. I have looked at intro files before when I originally set up system but do not recall seeing all the detail about audio
Thanks again for your interest
wandiligong
Tue Sep 08, 2015 1:33 pm
I have found info re changing output from AV to HDMI but experienced a lot of trouble getting HDMI video until I found that OpenElec Kodi will not output via HDMI no matter what I do in config.txt file. It will not shift from outputting via AV. BUT Raspian does output via HDMI in normal manner?
Hope to get some help from OpenElec forum but so far they talk about hdmi_force_hotplug=1 which I have already activated to get Raspian via HDMI
Confused why 2 op systems (OpenElec and Raspbian) output AV and HDMI respectively from the same Raspberry Pi?
wandiligong
Wed Sep 09, 2015 1:41 am
I am still in trouble with not being able to output OpenElec / Kodi V 14.2 via HDMI although Raspbian works fine via HDMI, all from my Raspberry Pi model B
I have edited the config.txt file via NOOBS and have only the following active (no hash)
Hdmi_safe=1
Config_hdmi_boost=4
Hdmi_force_hotplug=1
Also the NOOBS auto generated entries I have hashed out
#hdmi_ignore_hotplug=1
#sdtv_mode=2
I have run via Raspbian terminal the following commands and get:
Tvservice –s
State 0x120016 [DVI DMT (4) RGB full 4:3], 640x480 @ 60Hz, progressive
Tvservice –m CEA
Group CEA has 15 modes
Mode 1: 600x480 @ 60Hz 4:3, clock:25MHz progressive
Then lists modes 2,3,4,5,6,7,16,17,18,19,20,21,22,31 with corresponding screen resolutions etc
Tvservice –m DMT
Group DMT has 8 modes:
(prefer) mode 4: 640x480 @ 60Hz 4:3, clock: 25MHz progressive
Then lists modes 6,9,11,16,17,18,82 with corresponding resolutions etc
Can anyone assist me with this info re how to output OpenElec Kodi via HDMI?
wandiligong
Wed Sep 09, 2015 9:11 am
PROBLEM SOLVED
Looked at
http://www.htpcbeginner.com/edit-openel ... fig-addon/
Which explains how to install an OpenElec add on to easily edit config file
Installed this and changed video output to HDMI and all is well
Changed audio to AV in ordinary Kodi system screen and now have Kodi audio on AV and video via HDMI
Ground loop hum still there though!
Thanks to all who tried to help me
wandiligong
Wed Sep 09, 2015 9:13 am
