float **delta_clb_to_clb;
delta_clb_to_clb[id_x][id_y];2)
struct s_block {char *name; enum e_block_types type; int *nets; int x; int y;};
block = (struct s_block *) my_malloc (num_blocks* sizeof(struct s_block));
static void alloc_and_assign_internal_structures( struct s_block **original_block, int *original_num_nets)why the function alloc_and_assign_internal_structures uses a 2 level pointer on s_block, it's not for 2 d array?
3)
boolean **original_is_global
