Thinking of testing a little thing. By using a python3 script to find all primes till 100k (that would be 9591 prime numbers), writing those to a file onto the /boot.
If it's a buffer issue, there would most likely be a random letter or such here and there. But it will be a regular pattern, like every 17th line have a "!" or something like it in it.
If it is a partition issue, the file will have some major flaws.
Now, I don't have the time to do this. But I have the. py script ready.
# Generate prime numbers
# Based on an article from http://dunningrb.wordpress.com/
import datetime, sys, math
# Function to print message
def print_prime(x):
print (" Prime : %7i " %x)
# Function to search for prime numbers
# within number range
def find_primes(upper_limit):
count = 0
candidate = 3
while(candidate <= upper_limit):
trial_divisor = 2
prime = 1 # assume it's prime
while(trial_divisor**2 <= candidate and prime):
if(candidate%trial_divisor == 0):
prime = 0 # it isn't prime
trial_divisor+=1
if(prime):
print_prime(candidate)
count += 1
candidate += 2
return count
# Check if the script was called with a
# parameter. Use that as the upper limit
# of numbers to search
if len(sys.argv) != 2:
upper_limit=1000000
else:
upper_limit=int(sys.argv[1])
# Record the current time
startTime = datetime.datetime.now()
# Start the process
print ("")
print ("Starting ...")
print ("")
count = find_primes(upper_limit)
print ("")
# Measure and print the elapsed time
elapsed=datetime.datetime.now()-startTime
print (" Found %d primes in %s" %(count,elapsed))
print ("")
Made this as a simple benchmark, and i will go to 1 milion, so use this in terminal.
uh where "filename" is what ever u call it. lol, sorry but I had to write that, who knows, might be an American reading this.
The script doesn't as you see write anything into a (txt?) file as such, but I guess you know how.
Now I'm off to Stockholm's northen archipelago.
