greypower1
western digital drive package
Tue Sep 01, 2015 8:30 am
Just spotted this WD "offer" - It may be old news, I don't know.
US - http://store.wdc.com/promo/96259800
UK - http://store.wdc.com/promo/96259700
BMS Doug
Re: western digital drive package
Tue Sep 01, 2015 12:55 pm
That's a nice setup kit, I like their cable.
WD PiDrive.gif (18.64 KiB) Viewed 8093 times
(See the Install guide).
Doug.
PeterO
Tue Sep 01, 2015 1:08 pm
Looks good, but I couldn't see the current rating of the PSU.
Drive looks like it says 0.65A @ 5V on the case.
PeterO
RaTTuS
Tue Sep 01, 2015 1:41 pm
nice looking thing ;)
Covfefe
d3vbk
Tue Sep 01, 2015 2:26 pm
projpi.com has put up a 35% off coupon code for this.
BMS Doug
Wed Sep 02, 2015 7:43 am
d3vbk wrote:projpi.com has put up a 35% off coupon code for this.
Even with the discount it still seems a bit expensive. but I like the connector.
Doug.
Pi_Fanatic
Fri Sep 11, 2015 12:46 pm
Really, compared to what exactly ? a 1TB 2.5" WD Blue drive goes for $56.90
http://amzn.to/1LnFY70
A 256GB Thumb drive goes for about $75 and a 1TB Portable USB drive goes for about $45. A portable drive would entail multiple cords. So this solution uses one power cord and one data transfer cord, albeit a little clunky but will be refined over time.
It never ceases to amaze me when a cool new idea is offered and people respond with "Meh" or "it's expensive".
Ok I'll get off my soapbox now
Pi_Fanatic
BMS Doug
Fri Sep 11, 2015 1:13 pm
Pi_Fanatic
meh.
I said I liked the cable, in fact I said it twice.
Doug.
blachanc
Fri Sep 11, 2015 2:48 pm
Dhoo,
Not available yet in the USA northern suburb (Canada).
Ben
Autism/Asperger syndrome: what is your score on this quiz?
http://www.raspberrypi.org/forums/viewtopic.php?f=62&t=70191
mikerr
Tue Sep 22, 2015 9:44 am
1TB Pi Drive = 1TB WD USB3 drive + X cable + PSU + 4GB SD = £70
http://store.wdc.com/store/wdeu/en_GB/D ... d.13833200
1TB WD USB3 Drive = £48
http://store.wdc.com/store/wdeu/en_GB/D ... s_Portable
So that USB-X cable, 4GB SD and PSU is costing you £22
My only real gripe is that the drive appears to be uncased.
(there are USB-Y cables available, but not seen an exact replica of this one )
tokyostormdrain
Wed Sep 23, 2015 11:02 am
£45 promo price now.
I'm tempted to get one. I just got bittorrent sync and want to set up a low power always on backup/storage. Just need to find some sort of case to fit it all in
Wed Sep 23, 2015 11:16 am
tokyostormdrain wrote:£45 promo price now.
Yes very good value compared to a standard £40.00 USB Drive
http://www.amazon.co.uk/Samsung-Slimlin ... B008PABFX8
In the UK WDC supply a 5.1V 2A 10.2W PSU
http://store.wdc.com/store/wdeu/en_GB/D ... t_Wireless
adieu
Asus CS10 Chromebit / HP Envy 4500 Wireless Printer / Raspberry Pi Model 2B v1.1 / RealVNC Software...
dwcsjca
Sat Sep 26, 2015 4:10 pm
Hi, I'm on the WD team that supports the PiDrive and other RPi initiatives. Regarding enclosures for the PiDrive kit, during off-hours I created a few designs for DIY 3D-prints and posted them on thingiverse.com. If the response is positive, I hope to use the thingiverse view/download numbers to convince WD to fund tooling and make them more accessible to the community.
http://www.thingiverse.com/thing:993481
http://www.thingiverse.com/thing:999924
http://www.thingiverse.com/thing:1003585
http://www.thingiverse.com/thing:1030236
RaTTuS
Mon Sep 28, 2015 7:53 am
nice !
What is the actual connection to the HD a USB plug / socket or something different
Covfefe
dwcsjca
Mon Sep 28, 2015 3:48 pm
Thanks!
The HDD is "USB native" meaning that its I/O is a via a USB3 microB female connector on the drive. On the HDD's PCBA there's a SATA-to-USB bridge.
The drive is connected to the RPi via a special adapter cable we designed. We call it the "Dragon Cable" as it has three leads coming out of the connection to the HDD. The objective was to provide independent power to the HDD without an external USB hub and still have only one power source/adapter for the setup. Reduce the "clumsiness" of Pi+HDD setups.
The cable's three leads do this:
(1) 5V power input (via USB2 microB female connector). A 5V 2A adapter and USB2 extension cable are provided with the kit.
(2) HDD to Rpi USB port for data connection
(3) 5V power output to RPi power input (via USB2 microB male connector)
The Dragon Cable can also be used to connect the USB HDD to Android phones and tablets (which would otherwise not be able to accommodate the HDD's power requirement). And it can also connect the HDD to stick computers (like the Intel Compute Stick) without needing an external USB hub.
We'll be offering a kit without the HDD and SDcard (it'll contain the Dragon Cable, AC adapter and USB extension cable) so users that already have a USB drive can clean up their act too :)
BMS Doug
Mon Oct 05, 2015 8:13 am
dwcsjca wrote: We'll be offering a kit without the HDD and SDcard (it'll contain the Dragon Cable, AC adapter and USB extension cable) so users that already have a USB drive can clean up their act too :)
That is excellent news, I'll look forward to seeing it.
Is a 5V 2A supply going to be enough for the Pi and the drive?
Lets imagine that I've added a USB WIFI dongle to the Pi, they can be quite power hungry and peak power usage of the Drive will coincide with usage if the dongle.
Doug.
dwcsjca
Tue Oct 06, 2015 1:30 pm
Hi, the 2A supply should be sufficient in most cases. The drive's peak current is about an amp and its power connection is directly to the AC adapter, not to the Pi's USB port. The Pi has a voltage protection circuit to ensure that the SoC is the last thing to get starved if peripherals demand excessive current. If there's an overload I believe that either the current supply to the USB port(s) is shut down and/or the USB hub is shut down- I'm not sure and have asked the team to look into it. If the USB hub is shut down (data lines as well as power lines), the Pi would disconnect from the HDD even if the HDD is receiving power directly from the adapter.
But again, in most cases 2A should cover it. I'll try to get more definitive info; in the meantime, if others on the forum have better info, please chime in!
Thanks.
dwcsjca
Thu Nov 19, 2015 5:17 am
Hi, quick update on WD PiDrive product offerings:
-The PiDrive cable (enables powering of RPi and HDD without a USB hub) is now available separately
-The above cable is now offered in a bundle with the 5V power adapter and USB power cable
-The PiDrive kit now includes an enclosure that houses the RPi and HDD
All of the above are currently being offered at discount:
WD On-line store, UK:
http://store.wdc.com/store/wdeu/en_GB/D ... WD_PiDrive
WD Online store, US:
http://store.wdc.com/store/wdus/en_US/l ... WD_PiDrive
BMS Doug
Thu Nov 19, 2015 9:09 am
dwcsjca wrote:Hi, quick update on WD PiDrive product offerings:
Thank you, great news.
Doug.
blachanc
Fri Nov 20, 2015 6:34 pm
still no luck in Canada...
Ben
Fri Nov 20, 2015 6:47 pm
blachanc wrote:still no luck in Canada...
Ben
What has that got to do with this forum :?:
Western Digital should be your first point of contact :(
adieu
texy
Sun Nov 22, 2015 1:04 pm
Ben
What's it go to do with you? Please don't police the forum - play nice or not at all. If you have an issue, raise a report.
Texy
Sun Nov 22, 2015 1:33 pm
Ben
I was going to say Tweet at them, but their twitter account is protected (for some mysterious reason). So your best bet may be to pick up the phone and call WD at 1-877-934-6972. WD Store customer support hours: Monday-Thursday, 8:00 a.m. - 5:00 p.m. Pacific Time, and on Friday from 8:00 a.m. - 3:00 p.m. Pacific Time.
It seems odd that they supply that nice hard drive package to this side of the pond, but won't supply it to their northern cousins.
This is a doctor free zone.
Sun Nov 22, 2015 2:49 pm
Ben
Texy
Question marks denote asking a question for clarification, do not know what you feel Question Marks are for, please note a WHATEVER :!:
adieu
blachanc
Sun Nov 22, 2015 6:15 pm
Ben
Thanks douggie,
I wrote my "still no luck in canada" post in a hurry, after my first contact with WD (3 different calls). I should have mentioned that I already contacted them at the time(never post in a hurry :oops: ). After a second exchange with WD, things got really better, so there is still hope.
To all: Please lets keep this thread on topic, and if there any "Heat" to exchange, lets do it via PM...
Ben
Return to “For sale”
