Fght
which wifi dongle should i buy for my pi2 ??
Fri Aug 28, 2015 1:42 pm
i live in israel and need one not too expensive nor too cheap (not cheap because cheap products are often making trouble)
recommend me on one
Re: which wifi dongle should i buy for my pi2 ??
Fri Aug 28, 2015 5:20 pm
Fght wrote:i live in israel and need one not too expensive nor too cheap (not cheap because cheap products are often making trouble)
recommend me on one
https://www.raspberrypi.org/products/usb-wifi-dongle
Retired disgracefully.....
......to a more gentile life !
Fght
Fri Aug 28, 2015 7:12 pm
so if i want to buy this:
http://swag.raspberrypi.org/products/of ... ifi-dongle
they will ship it to israel too?
haven't saw anything about international shipping there.
i also need to buy 3 eu power suppliers for my 3 pi's + power cables.
the ones i've bought at modmypi.com were causing flickering on the tv's
kusti8
Fri Aug 28, 2015 7:19 pm
Fght wrote:so if i want to buy this:
They'll ship to Isreal, it'll just cost you 28 pounds to do it for a 6 pound device. But then you can buy in bulk, and get the eu power supplies from the Swag store as well.
Fght
Fri Aug 28, 2015 7:33 pm
i only need one.
Ok so what about this one for 20.5 USD?
http://www.talmir.co.il/product/7872.htm
the brand WIPI is good?
i don't know what to do. i don't want to keep wasting money on wifi dongles and power suppliers.
i already bought a power supplier from "TALMIR" but i keep seeing the under-voltage warning message.
Sat Aug 29, 2015 6:35 am
Fght wrote:i only need one.
Yes the WiPi is compatable
http://uk.farnell.com/element14/wipi/do ... dp/2133900
Fght
Sat Aug 29, 2015 1:19 pm
I will. Thank you
Fght
Fri Sep 04, 2015 9:51 pm
ok
so i've got my wipi. connected it and----- the same results.
any other way to solve it? the music pauses problem i mean
metalj
Fri Sep 04, 2015 9:54 pm
Startx
Goto menu top left
Goto run
Type wpa_gui
Run it
Hit scan
Double click on your WiFi
Enter password
Connect
Close
Backspace 28 times :)
Fght
Sat Sep 05, 2015 12:24 am
what exactly should this do?
do i need ssh for that and make the process from my desktop? is it simple to enable ssh after not choosing it at first boot wizard process?
metalj
Sat Sep 05, 2015 12:48 am
First instruction is startx so that means while running the gui. You said the music pause problem as if you have referenced it before. So are you on raspbian? My instructions work with wipi using raspbian. Which program is not working?
Fght
Sat Sep 05, 2015 2:23 am
no no no
i'm using openelec as the os
