CobraJet
Wired Ethernet not connecting
Wed Aug 26, 2015 8:29 pm
I have read and searched the boards, but i still cannot troubleshoot my ethernet connection. It indicates it is connected, but will not ping anything. I have tried to change cables and use a static ip, but no connection.
CobraJet
Re: Wired Ethernet not connecting
Wed Aug 26, 2015 9:09 pm
I've attached a couple of screenshots using the default RasPi interfaces setting in the Network folder and the other inputting the static settings manually.
ritesh20
Thu Aug 27, 2015 6:50 am
Have you assigned static proxy in /etc/network/interfaces..??
Do you have a Proxy server for your network?
