adelpctan
Raspberry Pi 2 Not working. Why?? (solved)
Wed Aug 26, 2015 2:29 pm
When powered on, green LED turns on, then goes off whilst red LED turns on and stays on, though not blinking at all.
From what I read, red LED not blinking suggests my Raspberry Pi 2 is not booting up normally.
At first, the TV displays a black screen with a header "Recorder 1 (raspberry)" for a second. This suggests HDMI port on TV has detected the Raspberry Pi. But then the screen becomes colorful as shown by attached pictures.
Next, the header text "Recorder 1 (raspberry)" disappears and leaves me with a blank colorful screen forever.
Has anyone encountered the same symptom?
Any idea what may be wrong with this Raspberry Pi 2 that I bought from ebay?
mahjongg
Re: Raspberry Pi 2 Not working. Why??
Wed Aug 26, 2015 3:35 pm
viewtopic.php?p=695146#p695146
Also, if the PWR LED turns of you did not apply enough voltage to the PI, either your supply cannot handle the required current, of you are using a bad power cable.
also read the boot problem sticky post.
adelpctan
Wed Aug 26, 2015 6:06 pm
Splash screen problem solved!!
Problem solved by reformatting SD card and installing the latest NOOBS.
Thank you!!
