stockton
bluetooth issue on RPiBv2
Mon Aug 24, 2015 6:14 am
I am attempting to get a Bluetooth dongle working with my Raspberry Pi Bv2 but failing.
The following appears in my logs:
[1364927.103431] Bluetooth: Core ver 2.19
[1364927.103570] NET: Registered protocol family 31
[1364927.103586] Bluetooth: HCI device and connection manager initialized
[1364927.103627] Bluetooth: HCI socket layer initialized
[1364927.103650] Bluetooth: L2CAP socket layer initialized
[1364927.103704] Bluetooth: SCO socket layer initialized
[1364927.111893] usbcore: registered new interface driver btusb
[1365349.662694] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[1365349.662727] Bluetooth: BNEP filters: protocol multicast
[1365349.662771] Bluetooth: BNEP socket layer initialized
[1365349.664452] Bluetooth: RFCOMM TTY layer initialized
[1365349.664523] Bluetooth: RFCOMM socket layer initialized
[1365349.664581] Bluetooth: RFCOMM ver 1.11
[1365793.623589] usb 1-1.3: USB disconnect, device number 5
[1365796.419469] usb 1-1.4: new full-speed USB device number 6 using dwc_otg
[1365796.524945] usb 1-1.4: New USB device found, idVendor=0c10,
idProduct=0000
[1365796.524974] usb 1-1.4: New USB device strings: Mfr=1, Product=2,
SerialNumber=3
[1365796.524992] usb 1-1.4: Product: SiW
[1365796.525008] usb 1-1.4: Manufacturer: SiW
[1365796.525025] usb 1-1.4: SerialNumber: 2600B0720200
[1366151.303297] usb 1-1.4: USB disconnect, device number 6
[1511194.617796] usb 1-1.3: new full-speed USB device number 7 using dwc_otg
[1511194.723225] usb 1-1.3: New USB device found, idVendor=0c10,
idProduct=0000
[1511194.723250] usb 1-1.3: New USB device strings: Mfr=1, Product=2,
SerialNumber=3
[1511194.723267] usb 1-1.3: Product: SiW
[1511194.723283] usb 1-1.3: Manufacturer: SiW
[1511194.723300] usb 1-1.3: SerialNumber: 2600B0720200
[email protected] ~ $ hcitool scan
Device is not available: No such device
[email protected] ~ $ lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 004: ID 18a5:0245 Verbatim, Ltd
Bus 001 Device 007: ID 0c10:0000
Please tell me what I have missed?
Douglas6
Re: bluetooth issue on RPiBv2
Mon Aug 24, 2015 1:19 pm
What make/model Bluetooth dongle? What does 'hciconfig -a' show?
stockton
Mon Aug 24, 2015 2:53 pm
The dongle is an Esquire bluetooth 60M
and hciconfig -a gives me
hci0: Type: BR/EDR Bus: USB
BD Address: 00:02:72:B0:00:26 ACL MTU: 120:20 SCO MTU: 0:0
DOWN
RX bytes:764 acl:0 sco:0 events:30 errors:0
TX bytes:96 acl:0 sco:0 commands:30 errors:0
Features: 0xff 0xff 0x05 0x38 0x18 0x18 0x00 0x00
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy:
Link mode: SLAVE ACCEPT
Douglas6
Mon Aug 24, 2015 3:03 pm
OK, try an 'hciconfig hci0 up'. You have installed BlueZ? What did you want to use Bluetooth for?
stockton
Tue Aug 25, 2015 5:16 am
I want to learn about Bluetooth communications. I already have garage door control via WiFi and now want to do the same with Bluetooth. I would also like to get a socket scenario developed using Bluetooth as I also have that using WiFi.
So basically it is a learning thing.
The command you suggested gives :-
[email protected] ~ $ hciconfig hci0 up
Can't init device hci0: Operation not permitted (1)
[email protected] ~ $ sudo hciconfig hci0 up
Can't init device hci0: Invalid request code (56)
stockton
Tue Aug 25, 2015 5:24 am
To answer your other question I have bluez installed. I did an install based on a suggestion I found on raspberrypi-spy.org.
sudo apt-get install --no-install-recommends bluetooth
If I attempt a reinstall I get:-
[email protected] ~ $ sudo apt-get install bluez
Reading package lists... Done
Building dependency tree
bluez is already the newest version.
bluez set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
Douglas6
Tue Aug 25, 2015 12:31 pm
stockton wrote:[email protected] ~ $ sudo hciconfig hci0 up
That's not good. I'm guessing your dongle is not supported. You might try Googling that error.
Tue Aug 25, 2015 12:42 pm
That is the BT Dongle and has no manufacturer listed, Googling seems to throw up many non detecting / working issues ;)
May be time to spend £5 on another Dongle :?:
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
