Jasimo
Invalid response packet from host
Thu Aug 20, 2015 8:10 pm
Since I am on Windows 10 with my notebook I got the following flooding my syslog when I am connected via ssh to the PI2 (latest firmware and raspbian wheezy)
avahi-daemon[2429]: Invalid response packet from host 192.168.2.124.
192.168.2.124 is the ip of my Windows 10 Notebook.
Can someone help me on this or got an idea?
Re: Invalid response packet from host
Thu Aug 20, 2015 10:24 pm
It's a known, but unresolved bug in Avahi.
http://avahi.org/ticket/352
There also doesn't seem to be any simple way to disable the logging.
Jasimo
Fri Aug 21, 2015 6:53 pm
thx for the info
bicklp
Mon Sep 14, 2015 12:02 pm
Any update on this?
i have a syslog filled with these
Sep 14 07:41:22 pi-server avahi-daemon[2628]: Invalid response packet from host 192.168.1.15.
Sep 14 07:41:47 pi-server avahi-daemon[2628]: Invalid response packet from host 192.168.1.15.
Sep 14 07:41:51 pi-server avahi-daemon[2628]: Invalid response packet from host 192.168.1.15.
someone here mentioed having a script to copy the log, get rid of the lines then put the log back? (bottom post)
https://bugs.launchpad.net/ubuntu/+sour ... ug/1342400
any on have any scripts to clear them out of the log?
bicklp
Mon Sep 14, 2015 12:11 pm
i think this will actually do it...
someone correct me if im wrong
should remove all lines containing 'Invalid response packet from host' from /var/log/syslog
sudo sed -i '/Invalid response packet from host/d' /var/log/syslog
if you want to create a backup of the syslog first you can use
sudo sed -i".bak" '/Invalid response packet from host/d' /var/log/syslog
this will create a syslog.bak file before making the changes
and then run as a cronjob or add a script into /etc/cron.hourly/
mwk
Thu Feb 04, 2016 4:09 pm
Or you could do this and black hole the crap (just sayin)
add this to /etc/rsyslog.conf (and yes I know the &~ is deprecated but using the newer stop seems to stop all logging) and then run sudo /etc/init.d/rsyslog restart and check your log files.
#### RULES ####
if $fromhost-ip == '127.0.0.1' then {
if $msg contains_i "Invalid response packet from host" then action(type="omfile" file="/dev/null")
RottenRonnie
Wed Apr 27, 2016 7:38 am
Your fix worked like a charm. Thanks! :D
mwk wrote:Or you could do this and black hole the crap (just sayin)
#### RULES ####
