chris12892
Bizzare issues with serial port(s)
Wed Aug 19, 2015 1:28 am
I have a Raspberry Pi 2 running Debian Jessie upgraded using the apt-get dist-upgrade method. Nothing has been done to the pi other than installing Jessie and running rpi-update. The unit has a 2.1A power supply.
I'm having a bizarre issue with both the onboard serial ports as well as FTDI chipsets and also a Prolific chipset. The ACM driver for the Arduno Uno works (mostly?) fine. I did disable the terminal on the onboard serial port before testing (using raspi-config).
Basically if I connect one of the offending chipsets (or use the onboard serial port) and then use stty to set the baud rate, then try to cat /dev/ttyUSB0 > /home/pi/log.txt, I'll either get 0 bytes in the log, or the log will contain lots of corrupt data (data out of order from how it was sent). Behavior is extremely inconsistent, so it's a little hard for me to provide much more detail then that.
Any ideas on what may be going on here?
chris12892
Re: Bizzare issues with serial port(s)
Wed Aug 19, 2015 6:54 am
Just an update to this...
After some hours, I found that this bizarre behavior isn't limited to the PI, it's happening on desktop Ubuntu too. it seems like bytes are getting dropped or something. But the question still stands, I suppose. Has anyone had any luck reading from an FTDI USB to serial bridge with the Raspberry PI using the C++ termios API?
Douglas6
Wed Aug 19, 2015 3:08 pm
The onboard UART (TX/RX pins) will appear at /dev/tty0, I believe.
scotty101
Wed Aug 19, 2015 3:24 pm
Douglas6 wrote:The onboard UART (TX/RX pins) will appear at /dev/tty0, I believe.
Nope. /dev/ttyAMA0
Source: http://elinux.org/RPi_Serial_Connection ... erial_port
Douglas6
Wed Aug 19, 2015 3:26 pm
Nope. /dev/ttyAMA0
Grrrr, of course, sorry.
chris12892
Thu Aug 20, 2015 9:00 am
Just an update....
It appears as though I managed to fix this. It ended up being some combination of flags that allowed it to work. For anyone else having odd serial issues, here's the code I used to start a serial port connection for nonblocking reads.
	struct termios tio;
	// Serial config
	memset(&tio, 0, sizeof(tio));
	tio.c_iflag = 0;
	tio.c_oflag = 0;
	tio.c_cflag = CS8 | CREAD | CLOCAL;
	tio.c_lflag = 0;
	tio.c_cc[VMIN] = 0;
	tio.c_cc[VTIME] = 0;
	// Open the device
	tty_fd = open(path.c_str(), O_RDWR | O_NOCTTY | O_NDELAY);
	// Check if the port didn't open correctly
	if (tty_fd==-1)
		return 0;
	// 115200
	if (cfsetospeed(&tio, B115200) || cfsetispeed(&tio, B115200))
		return 0;
	cfmakeraw(&tio);
	tcflush(tty_fd, TCIFLUSH);
	tcsetattr(tty_fd, TCSANOW, &tio);
KLL
Thu Aug 20, 2015 12:16 pm
hi CHRIS,
last 2 days i am investigating a other funny serial problem
-a- i have a arduino UNO
- connected and powered by RPI - USB - see 5.07V at arduino
- with good code what allow me to see ( in this respect )
- - a reboot
- - some slow diag msg show that all running well
- - a input of a character ( serial menu.. project ) has a clear response.
-b- i had a full updated raspbian, but to recheck burned raspbian 05052015 today again.
-c- i used the serial port software
-c1 ARDUINO IDE 101 serial monitor
-c2 screen
-c3 minicom
no matter what system and what software i used,
the arduino reboots at connection OR NOT.
p.s. on WIN7 pc its clear that the arduino IDE serial monitor causes a reboot
but the HTERM with DTR OFF can connect without reboot! ( both well defined )
all details see http://kll.engineering-news.org/kllfusi ... icle_id=97
can you possibly confirm with your above code if arduino UNO is rebooting on connection?
