VonHatte
OutputOpenDrain
Mon Aug 17, 2015 10:55 am
I am doing project where I need to use GPIO pins as OutputOpenDrain. Problem is that when I am setting drive mode in code I get exception that says that drive mode is not supported.
To the actual question: Is it that Raspberry Pi 2 does not support OutputOpenDrain mode at all or are only few of them supporting it (I tried this on several GPIO)? Does anyone know any workaround that I could use (preferably without any changes to electronics)?
Re: OutputOpenDrain
Mon Aug 17, 2015 11:48 am
VonHatte wrote:Hi,
This is the Raspberry Pi 2B GPIO web page for Windows 10 IoT Core:
https://ms-iot.github.io/content/en-US/ ... gsRPi2.htm
http://ms-iot.github.io/content/en-US/w ... Coding.htm
RPi 4B 4GB (SSD Boot)..
Re: OutputOpenDrain
Mon Aug 17, 2015 1:16 pm
The Raspberry Pi GPIOs do not have an Open Drain Output mode.
[edit] I suppose you could emulate by setting the GPIO to Input when you would set Open Drain output high, and Output Low when you would want to pull it low. That way it would pull down when "0" and float when "1".
and plugwash has beaten me too it :)
plugwash
Re: OutputOpenDrain
Mon Aug 17, 2015 1:18 pm
You can simulate open drain by setting the output value to 0 and then using the direction register as your output signal.
VonHatte
Re: OutputOpenDrain
Mon Aug 17, 2015 6:27 pm
Thank you all for answering. I tried using normal output without knowing raspberry pi in internal circuitry and it seems to work. It's not optimal so I'm going to give a try direction register.
Thank you all!
