from flask import Flask
from flask import render_template
from flask import request
from flask import redirect
import time
temp = ""
t = ""
fan_High = 0
fan_Med = 0
fan_Low =0
fanspeed = ""
app = Flask(__name__)
@app.route('/form', methods=['POST'])
def aziz():
global temp ,fanspeed
fanspeedlocal = ''
if request.form['settemp'] != "":
temp = request.form['settemp']
templocal = temp
else:
templocal = temp
if request.form['speed'] == "null":
fanspeedlocal = fanspeed
else:
if request.form['speed'] == "High":
fan_Med = False
fan_Low = False
fan_High = True
fanspeed = "High"
elif request.form['speed'] == "Med":
fan_High = False
fan_Low = False
fan_Med = True
fanspeed = "Medium"
elif request.form['speed'] == "Low":
fan_High = False
fan_Med = False
fan_Low = True
fanspeed = "Low"
print 'Settemp = %s' %temp
print 'fanspeed = %s' %fanspeed
return render_template('Output.html',temp=templocal,currtemp=strct,time=t,fanspeed=fanspeedlocal
@app.route('/')
def start():
global t , fanspeed
t = time.strftime("%H:%M:%S")
return render_template('Start.html',temp=temp,currtemp=strct,time=t,fanspeed=fanspeed)
if __name__ == '__main__':
app.debug = False
app.run(host = '192.168.1.101')
var = 1
while var == 1:
inttemp = int(temp)
if currtemp >= inttemp:
#set GPIO to high
else:
#set GPIO to low
if fanspeed == 'High':
#set GPIO to high
elif fanspeed == 'Med':
#set GPIO to high
elif fanspeed == 'LOW':
#set GPIO to high
time.sleep(10)
