I have Raspbian. My system at home has a wireless router/modem with four ethernet ports or switches I guess. A network drive is attached to the router with an ethernet cable. I can access the network drive over wireless on my WIN7 laptop because I mapped the drive. I can also enter the IP address of the drive into the address window on an internet browser and it then uses Flash to access the drive and can of course ping the drive from the laptop. I have a desktop running Ubuntu and can access the network drive on that PC going through file manager in the Ubuntu GUI. Before I installed Raspbian on the RPi I had Debian Squeeze and could access the network drive by going File Manager. I could ping the drive when using Debian but could not access it by putting the IP address in an internet browser address window because there was no Flash support.
With Raspbian I cannot access the network drive through file manager. In file manager I click on "go" in the tool bar then click on "Network drives" then I get a pop up window that is headed "error" and the window says "operation not supported". What do I need to do to access the drive. I know its IP address but can't use a browser to access it because there is no support for flash.
