ferrymanr
apt-get update problem
Thu Jul 19, 2012 11:02 pm
With the new release 2012-07-15 apt-get is working and have had no problems installing some packages. However apt-get update fails every time :-
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Fetched 7,355 kB in 1min 5s (112 kB/s)
Reading package lists... Error!
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/apt/lists/mirrordirector.raspbian.org_raspbian_dists_wheezy_contrib_i18n_Translation-en
E: The package lists or status file could not be parsed or opened
Any idea what's wrong?
redhawk
Re: apt-get update problem
Thu Jul 19, 2012 11:07 pm
What are you trying to install??
Richard S.
ferrymanr
Thu Jul 19, 2012 11:15 pm
Just running "sudo apt-get update". This usually runs cleanly.
Richard
Leestons
Sun Jul 22, 2012 2:20 pm
I'm having the same problem, but I also seem to be having it with any package I try to install.
Any help guys?
decibyte
Mon Jul 23, 2012 7:32 pm
After messing everything up trying to fix this problem, I copied the Raspbian image to the SD card again, and now it all works just fine.
Leestons
Fri Jul 27, 2012 5:48 pm
decibyte wrote:After messing everything up trying to fix this problem, I copied the Raspbian image to the SD card again, and now it all works just fine.
I tried doing what you said and had no luck at all
[email protected] ~ $ sudo apt-get update
Hit http://archive.raspberrypi.org wheezy InRelease
Hit http://mirrordirector.raspbian.org wheezy InRelease
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://archive.raspberrypi.org wheezy/main Translation-en
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en
E: Problem with MergeList /var/lib/dpkg/status
E: The package lists or status file could not be parsed or opened.
PaulCheffus
Fri Jul 27, 2012 7:37 pm
Hi
I have a similar problem apt-get update and apt-get upgrade do nothing and uname -a returns 168 yet other people have mentioned version 202.
In addition vcgencmd doesn't do anything.
Any idea what I have done to my image?
Cheers
Paul
Procrastination - The Thief of Time.
theZacAttacks
Fri Jul 27, 2012 8:58 pm
I had the same problem. Restoring the image didn't work, however.
I did fix it, though, by deleting /var/lock/dpkg/status and then touching a new one (sudo touch /var/lock/dpkg/status).
After that apt-get update ran fine.
Leestons
Fri Jul 27, 2012 10:11 pm
theZacAttacks wrote:I had the same problem. Restoring the image didn't work, however.
I want to buy you a cold refreshing pint (or a cola if you don't drink) thank you SO much! I've been dealing with this for a week with no luck, and you have just solved all my problems, I cannot thank you enough.
douglas
Tue Jul 31, 2012 1:37 am
I thought I had same/similar problem. Tried the touch status thing, no go. Then I realized I never plugged in the ethernet cable... DOH :oops: !! Plugged it in and it works fine.
i42n
Fri Aug 31, 2012 10:21 am
I experience the same problem with a fresh installed Raspbian “wheezy”. When I boot up the first time and log in with ssh and then do a "sudo apt-get update" I get the following error:
Get:1 http://archive.raspberrypi.org wheezy InRelease [7,701 B]
Get:2 http://mirrordirector.raspbian.org wheezy InRelease [12.5 kB]
Get:3 http://archive.raspberrypi.org wheezy/main armhf Packages [5,744 B]
Get:4 http://mirrordirector.raspbian.org wheezy/main armhf Packages [7,333 kB]
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Get:5 http://mirrordirector.raspbian.org wheezy/contrib armhf Packages [23.3 kB]
Get:6 http://mirrordirector.raspbian.org wheezy/non-free armhf Packages [46.5 kB]
Get:7 http://mirrordirector.raspbian.org wheezy/rpi armhf Packages [14 B]
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Fetched 7,428 kB in 57s (130 kB/s)
I tried resetting the dpkg list as descriped above but it did not help. Any suggestions?
i42n
Fri Aug 31, 2012 10:26 am
I have the same problem.
Reinstall does not help as I get this error also on a fresh installed raspi. Internet connection works. I also tried the dpkg status thing but no luck.
Any suggestions?
yongly
Sun Sep 16, 2012 9:23 am
Just a FYI. The dpkg status thing worked for me.. except instead of /var/lock/dpkg/status it was /var/lib/dpkg/status like it says in the error.
Andumon
Mon Dec 10, 2012 8:37 pm
Thanks for this tip, i was driving crazy
pe7er
Sat Dec 15, 2012 5:57 pm
Thanks!
sudo rm /var/lib/dpkg/status
sudo touch /var/lib/dpkg/status
worked for me. After that I was able to update with "sudo apt-get update" without problem.
Kind regards,
Peter Martin
OS: Debian 8, Raspbian
mbeffa
Sun Mar 10, 2013 3:17 pm
I tried everything others suggested. If I ran apt-get update, it freezes after a few seconds. Then I have to unplug it to reboot. I do not have a monitor, just ssh. I am getting HIGHLY disappointed with this device.
[email protected]:/var/lib/dpkg$ sudo mv status status.save
[email protected]:/var/lib/dpkg$ sudo touch status
[email protected]:/var/lib/dpkg$ sudo apt-get update
Get:1 http://mirrordirector.raspbian.org wheezy/main armhf Packages [7,402 kB]
Get:2 http://mirrordirector.raspbian.org wheezy/contrib armhf Packages [23.3 kB]
Get:3 http://mirrordirector.raspbian.org wheezy/non-free armhf Packages [48.0 kB]
Get:4 http://mirrordirector.raspbian.org wheezy/rpi armhf Packages [14 B]
100% [1 Packages bzip2 0 B]
and then nothing.
Gomoto
Sun Mar 10, 2013 10:56 pm
mbeffa
are you using a wifi dongle pluged into the raspberry directly?
mbeffa
Sun Mar 10, 2013 10:59 pm
Yes, it has a Wifi dongle, but I did not get to connect wireless. It just sits there.
mbeffa
Sun Mar 10, 2013 11:05 pm
WOW!. Just tried it without the dongle ( sudo apt-get update) and IT WORKED. Amazing
mbeffa
Tue Mar 12, 2013 3:18 pm
After removing the WiFi dongle, I was able to run the update clean, but then, whatever I try to install,
it hits the libgcc1 dependency:
sudo apt-get install libgcc1
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
libgcc1
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
Need to get 0 B/54.4 kB of archives.
After this operation, 203 kB of additional disk space will be used.
[email protected]:~$
After two days of fiddling with this device, I am ready to send it back. Seems to be good only for selected few super-smart users. Maybe somebody can enlighten me at the last hour, but I am so far from mysql, tomcat, apache and wifi...
RaTTuS
Contact: Twitter YouTube
Tue Mar 12, 2013 3:25 pm
start afresh
reflash
expand rootfs
sudo apt-get update && sudo apt-get upgrade -y
see that it is stable
then start adding the things you want
Covfefe
mbeffa
Tue Mar 12, 2013 3:49 pm
Thank you for the quick reply, but what do you mean by
start afresh
reflash?
Burn another flash? I can try to do that, but I am assuming it will take one day.
I bought the pi with a $10 flash card which started it up. Once I ran apt-get update, I assumed it installed the latest and greatest.
I really do not know where to go to "start afresh". Seems to be more info than functionality out there.
Spid
Tue Mar 12, 2013 4:28 pm
I will always assume you are running Raspbian for desktop and Raspbmc for XMBC !
Conaz9847
Wed Mar 20, 2013 10:05 pm
I had the same problem, but after reading all the posts
This worked, thanks Guys :D
plugwash
Tue Apr 16, 2013 11:58 pm
/var/lib/dpkg/status , it's the main list of all packages that are installed on your system. Removing it and replacing it with an empty file will mean that the package manager doesn't know any packages are installed which is almost certainly NOT what you want.
There have also been a couple of recent posts in this thread which look unrelated to the issues discussed here (which seem to be problems with corrupt package lists. I've split them off into their own threads.
Return to “Raspbian”
