I'm asking if there are any COAX input for the Raspberry Pi B+ (addons) that I can use with Kodi.
It's for watching live TV from antenna and use it as a DVR.
USB TV Tuner based on a Realtek rtl2832u chipset are well supported under Linux Operating Systems.felixinx wrote:Hi,
http://lmgtfy.com/?q=Realtek+rtl2832u+kodifelixinx wrote:Thanks for your answer. Can you provide more info on what you said?
Confused as confused, where the Aerial plugs in is a standard TV Aerial Cable Coax Input..felixinx wrote:Yes, I have seen this.
But can we enter a COAX cable inside this USB dungle? From an extern TV antenna?
For example, in in this product, I can see that there is the USB dungle, and then an antenna, but I don't see any COAX input.
Do you know a good place to buy it?
What country are you in ?felixinx wrote:This is not cable TV. I have no provider, it is only OTA TV. With an antenna, directly on the TV.
So this one with this one should fit? Thats seems OKgordon77 wrote:They sell these adaptors in Canada...to suit the USB stick you linked to....
http://www.amazon.ca/Type-Female-Coaxia ... ax+adaptor
Yes should fit. I haven't used the USB stick.felixinx wrote:So this one with this one should fit? Thats seems OKgordon77 wrote:They sell these adaptors in Canada...to suit the USB stick you linked to....
