The model a+ has only one USB port. How do
keyboard and mouse connect?
Most of my keyboards have USB ports on them (i.e., the keyboard has an internal USB hub). So, the mouse gets plugged into the keyboard.Celtic wrote:The model a+ has only one USB port. How do
Which kinda defeats the whole purpose, doesn't it?DougieLawson wrote:Since you normally need a WiFi (or wired ethernet) USB dongle and keyboard and mouse it's usually impossible to run a A+ without a USB hub.
Not really. The A+ has the same, improved, power regulation that the B+/Pi2B have, so one can use an unpowered hub to power everything that one would attach to a B+.Joe Schmoe wrote:Which kinda defeats the whole purpose, doesn't it?DougieLawson wrote:Since you normally need a WiFi (or wired ethernet) USB dongle and keyboard and mouse it's usually impossible to run a A+ without a USB hub.
I mean, add in the hub (including the increased power draw from having all those things connected) and you've essentially got (some variety of) a B.
The only exception I can see is if you use the one single USB port for either WiFi or wired ethernet and run the thing "headless".
