Hi there!
I am currently working on a project with a friend which aims to push a button connected to an aerosol in many increments. To give an impression, we need approximately 100 steps in the space of the 1cm compression depth.
So far, we are planning to go for a Raspberry Pi 2 approach here [1] in combination with a Gertbot Motor Control Board here [2] in order to power a Linear Stepper Motor to push the button. One of the candidates for this motor is the RS 28.1N Stepper Electric Linear Actuator, 12V dc, 48mm Stroke found here [3] and we have a few questions around suitability and compatibility:
1. Most importantly, we’d like to confirm that this motor is indeed compatible with the Gertbot & Raspberry Pi 2 combo. Otherwise, we’re a little dead in the water!
2. Secondly, we have noticed that there is a 5V power supply required to power the Raspberry Pi 2 and we have found a 12V Electric Motor. Does this mean we need to purchase some kind of transformer or extra power supply to step up the voltage or is this handled by the Gertbot board itself?
3. We would like to write C# .NET code with the Windows 10 Internet of Things operating system. Can we operate the motor plugged into the Gertbot this way?
We would appreciate any help as we are both software developers with very limited experience in electronic engineering!
Links Provided:
[1]: http://uk.rs-online.com/web/p/products/8326274/
[2]:http://uk.rs-online.com/web/p/products/8486806/
[3]: http://uk.rs-online.com/web/p/products/4540990/
