DGeronimo
additional lid for raspberry pi 2 case
Wed Aug 12, 2015 8:59 am
Hi all,
I have just received my official raspberry pi 2 case and I was wondering if there are any alternative lids for these case. I'm going to use my pi as a media center and need access to the gpio's. The pi will be placed behind my tv and I don't want to let the case open, lots of dust and stuff. In my previous case i drilled a hole for the cables, but this new case is just to beautiful to drill holes in :d
Does anybody know if you can order lids who have holes for gpio in it?
Thank you.
Kind regards
W. H. Heydt
Re: additional lid for raspberry pi 2 case
Wed Aug 12, 2015 3:46 pm
Leave the side off next to the GPIO pins. Alternatively, get out a Dremel and cut a slot where you need it.
jdb
Wed Aug 12, 2015 8:40 pm
W. H. Heydt wrote:Leave the side off next to the GPIO pins. Alternatively, get out a Dremel and cut a slot where you need it.
^ This
The side next to the GPIO pins was designed with enough clearance to fit a standard 40-way ribbon cable connector, if necessary. If your requirements are such that you need wires coming out the top, then by all means take your Pi case to a pillar drill.
Rockets are loud.
https://astro-pi.org
InsideJob
Thu Aug 13, 2015 4:30 pm
DGeronimo wrote:Does anybody know if you can order lids who have holes for gpio in it?
So the answer is NO, NEVER!! Stop asking!!! Mod it with a sledgehammer and chainsaw if you want. But then it'll be an unofficial case and won't be supported by The Foundation.
Dremel worked for me.
Return to “Off topic discussion”
