I have installed Raspbian os on Raspberry pi 2. I am setting wifi with static ip. The configuration in:
/etc/network/interfaces
auto wlan0
#allow-hotplug wlan0 #also tried it without comment
iface wlan0 inet static
address 192.168.2.101
netmask 255.255.255.0
#also tried with /without broadcast
gateway 192.168.2.1
dns-nameservers 202.56.215.54
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
/etc/wpa_supplicant/wpa_supplicant.conf contents
network={
ssid="mySSID"
psk="myPassword" #simple password key. not encrypted.
key_mgmt=WPA-PSK
# also tried many other options like proto, scan_ssid etc.. My SSID is not hidden
Sometime my internet is working and sometime not. If it works then it is so slow. The problem is that in GUI (desktop) the wifi icon at top-right corner of the screen is showing the different IP not the static IP that I set in /etc/network/interfaces.
Can anyone tell me how it will use only one static IP. i.e. the wifi icon should show the same IP that is in .../interfaces file.
I have spent many days trying from google but internet is still not working properly.
Thanks,
Hem Singh
