Did anyone changed the sensor from the RPi Cam board?
I will need a larger size sensor, and looking to the OmniVision camera sensors specs most are having same power input design (core 1.5V, analog 2.8V, pin connection to the board...) for larger sizes.
Basically, just scrap the $ 5 sensor with the black lens plastic casing, and place a larger sensor, but not sure if the board supports that?
of couse you need some attention with pins connection and reconnect to the P5V04a SUNNY A1346 tiny connector, but I think is Possible.
Advise is welcomed.
Technical data RPi:
http://elinux.org/Rpi_Camera_Module
Omnivision Sensors Technical Data:
http://www.ovt.com/products/category.php?id=11
Particular OV5648 (not OV5647, that i belive is the same, but for RPi)
http://www.ovt.com/download_document.ph ... nsorid=178
and can the RPi board support this 23 Megapixels with same power supply and pins?
http://www.ovt.com/download_document.ph ... nsorid=170
