thinker98 wrote:I still have the failure code
after doing a full overwrite
can I fix this
cause in the failure it says I could fix it manually
sorry, no idea
but i can confirm that
- download 2015-07-02_2015-05-05-octopi-wheezy-0.12.0.zip
- unzip: get 2015-05-05-octopi-wheezy-0.12.0.img
- win32diskimager 2015-05-05-octopi-wheezy-0.12.0.img to 8GB SD card
(+) edit octopi-network.txt
- boot in RPI
(+) on HDMI it boot direct to raspi-config screen ( no error )
(+) connect ethernet cable ( to IP from router info )
( or fix IP in octopi-network.txt
auto eth0:1
iface eth0:1 inet static
address 192.168.1.101
windows + putty SSH login pi@192.168.1.101 pw raspberry .. works also
pls do
sudo raspi-config to expand filesystem first.
the text in octopi-network.txt: browser by going to
http://192.168.250.1 ?? i not understand, but
browser
http://192.168.1.101 worked ( very slow ) popup login config screen.
so, as i had no error ... HDMI boot
and ethernet cable to router works for SSH and even webserver,
i have no idea what's wrong with your system.
still see the options / wrong image / bad SD / bad octopi-network.txt change/
more info:
http://reprap.org/wiki/OctoPrint https://github.com/foosel/OctoPrint/wiki/FAQ
