afanasjev
Compute module with 2 cameras and I2C
Wed Jul 29, 2015 10:34 am
I would like to use ComputeModule I2C with two cameras attached. The I2C pins are connected to GPIO pins regarding documentation, so all I2C pins are busy. Is it possible to connect i2c perihperals in such situation?
How the connection schematics will look like?
ShiftPlusOne
Re: Compute module with 2 cameras and I2C
Wed Jul 29, 2015 10:59 am
The pins in the documentation were only chosen because of their convenient location and serve only as an example. You are free to use any other unused pins, as long as your dt-blob reflects that.
6by9
Wed Jul 29, 2015 11:18 am
Agreed. Use pins other than 2&3 for LED and shutdown (4&5 have been used by others), and amend /boot/dt-blob.bin lines
pin_define@CAMERA_0_LED { type = "internal"; number = <2>; };
pin_define@CAMERA_0_SHUTDOWN { type = "internal"; number = <3>; };
to point to your new pins. You can then enable i2c_arm in config.txt to give you access to /dev/i2c-1 on GPIOs 2&3.
Or use the standard pins for the camera, and route i2c-1 to GPIOs 44 & 45 (J6 pins 33&35 on the IO board) by switching them to ALT2 (you'll need to amend the i2c pin usage in the device tree to avoid changing the function on pins 2&3 from output to ALT0).
In either case you'll need to add your own I2C pull up resistors.
