rubiks
Can't mount my harddrive (Solved)
Wed Jul 29, 2015 3:50 am
I try to mount my harddrive to my Rpi as a shared drive.
I can see my harddrive under
lsusb
but I can't see it under
sudo fdisk -l
Please help.
My western digital is portable drive power through pi's usb and I have changed the /boot/config.txt with
max_usb_current=1
Harddrive format NTFS and installed
sudo apt-get install ntfs-3g
Solved: not enough power to powered the external drive.
Dorian_WD
Re: Can't mount my harddrive
Wed Jul 29, 2015 6:43 am
Hey rubiks,
How is the hard drive formatted and can you share the exact model of the HDD as well as its capacity? You can check this topic for some ideas: viewtopic.php?f=28&t=69565
Regards,
Dorian_WD
Wed Jul 29, 2015 8:16 am
What does the lsusb show for your hard drive? It might be that the adaptor is not supported.
Also, the output from dmesg can be useful. Plug your drive in to the Pi, wait about 3-4 seconds, then do "dmesg | tail -20" then post the results of that.
