shafirdo
Raspberry Pi 2 don't work
Mon Jul 27, 2015 4:14 pm
I have a new Raspberry Pi 2, at the first time it worked, but now the two ligths are on (green and red) but there no sinal on the TV.
Doron
ThomasS
Re: Raspberry Pi 2 don't work
Mon Jul 27, 2015 4:38 pm
Is the green light flashing? If not I'd order a new SD card or reflash the existing one using a computer. It seems likely you didn't shut down the Pi properly, corrupting the SD card.
ThomasS
kusti8
Mon Jul 27, 2015 6:30 pm
Read the not booting sticky in the Troubleshooting section, that address all the common problems.
shafirdo
Tue Jul 28, 2015 4:04 am
When connecting power, the two light up together.
Regardless of whether a card is inserted or not.
And the system does not rise.
Tnx
Doron
B.Goode
Tue Jul 28, 2015 6:26 am
shafirdo wrote:When connecting power, the two light up together.
This situation is clearly described in the Troubleshooting document in these forums. viewtopic.php?f=28&t=58151
The ACT LED is essential in determining if the Pi can actually read from the card. If the ACT LED doesn't blink quickly in an irregular pattern for at least twenty seconds, this indicates that the Pi cannot read from the SD card, and that booting is not taking place. It doesn't matter if the ACT LED initially starts on or off. It is only the blinking of the ACT LED is significant. A dim ACT LED also has no significance beyond the fact that you are using a B. From the model B+ onwards, the LED is driven differently, and is brighter.
With no SD card inserted, note how the ACT LED behaves. Now insert a programmed card: that behaviour should change, and, if it does not, this indicates that Pi cannot see the necessary files on the SD card.
shafirdo
Tue Jul 28, 2015 6:39 am
This is me Raspberry: Pi 2 Model B Broadcom BCM2836 1G RAM
B.Goode
Tue Jul 28, 2015 7:02 am
shafirdo wrote:This is me Raspberry: Pi 2 Model B Broadcom BCM2836 1G RAM
Congratulations. You can have a lot of fun with that.
Now you need a working microSD card to go with it.
