JohnBeardmore
apt-get gets confused
Mon Jul 27, 2015 12:06 am
I think I've broken something in package management.
Whenever I try to apt-get install, remve or upgrade, the process finished with a message of the form below.
I've tried removing and installing python3-minimal and python3 but it hasn't changed the situation. Any idea how I might fix this without reinstalling?
Cheers, J/.
Reading package lists...
Building dependency tree...
Reading state information...
Package 'logrotate' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up python3-minimal (3.2.3-6) ...
File "/usr/bin/py3compile", line 34, in <module>
from debpython.version import SUPPORTED, debsorted, vrepr, \
EOFError: EOF read where not expected
dpkg: error processing python3-minimal (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of python3:
python3 depends on python3-minimal (= 3.2.3-6); however:
Package python3-minimal is not configured yet.
dpkg: error processing python3 (--configure):
dependency problems - leaving unconfigured
python3-minimal
python3
Author of oBeMS open source Building energy Management System.
Automatic Meter Reading (AMR), Building Management System (BMS),
Building Energy Management System (BEMS), Infrastructure Control System (ICS).
See: http://t4sustainability.co.uk/oBeMS/
InsideJob
Re: apt-get gets confused
Tue Jul 28, 2015 1:08 pm
Sometimes I have to do an apt-get purge instead of remove to whack messed up config files. It's also possible something installed an older version of minimal and that's why it fails. apt-cache showpkg will give you the reverse depends.
JohnBeardmore
Tue Jul 28, 2015 11:44 pm
Thanks, but it didn't help.
I really don't know how apt works, so it's magic when it does, and black magic when it doesn't.
Why would having an older version make it impossible to remove ?
It does, but what does this tell me ?
Cheers, J/.
Return to “Raspberry Pi OS”
