I have a RPi Model B. On the board is printed "(c)2011.12". I assume this is the first revision.
I want to use:
- Tontec 3.5 Zoll Raspberry Pi Touch Screen Display Monitor 480x320 LCD Touchscreen Kit (to be bought)
- EDIMAX EW-7811UN Wireless USB Adapter
- Samson Meteorite USB Microphone (to be bought)
- GENIUS SP-HF150 Speakers (to be bought)
and Raspbian. Currently I have a 1.2A PSU. Is this enough, do I have to upgrade or is it not possible?
I am not sure about:
- the max Current on the Micro-USB port
- backfeed powering support on my Pi
- how serious the impact of a usb-charger is (I know that there can be unstable voltages when using a USB-Charger which leads to freezes/shutdowns, but I don´t know if this is a theoretical or a frequently occouring problem or if it depends on the actual used charger)
I need at least 3 USB Powering Ports (for the Pi, the Speakers and a Phone), therefore I would like to have a USB-Wallcharger with multiple Ports (like the "Anker 20W 4-Port USB") as a PSU but I have doubts about the stability of the Pi. Does someone has experience with using such a Supply?
Thank you in advance for your time
