The source is for 0.8rc1, this is unchanged since 2013 but you can substitute if a newer version gets out, or if you prefer an older version of course.
# Install dependencies
apt-get install libtool debhelper automake autoconf gcc g++ libc6-dev libncurses5-dev conntrack libnfnetlink-dev libnetfilter-log-dev
# Download source
cd /usr/src
wget ftp://ftp.vuurmuur.org/releases/0.8rc1/Vuurmuur-0.8rc1.tar.gz
tar -xzf Vuurmuur-0.8rc1.tar.gz
cd Vuurmuur-0.8rc1
# Prepare the source directories
bash install.sh --unpack
# Build the packages and install. These 3 packages must be built in order:
cd libvuurmuur-0.8rc1
dpkg-buildpackage
cd ..
dpkg --install libvuurmuur_0.8~rc1-1_armhf.deb
cd vuurmuur-0.8rc1
dpkg-buildpackage
cd ..
dpkg --install vuurmuur_0.8~rc1-1_armhf.deb
cd vuurmuur_conf-0.8rc1
dpkg-buildpackage
cd ..
dpkg --install vuurmuur-conf_0.8~rc1-1_armhf.deb
# Done
- set /etc/default/vuurmuur to VUURMUUR_START=1
- service vuurmuur start
- Use vuurmuur_conf for configuration
I re-used an existing config from an x86 machine so did not go through the initial setup on the arm pi.
Let me know if anything needs to be added.
All the best,
Dave Driesen
Linux Dev and oldskool elite
