vidrus
Remove RPI Logo on startup
Wed Jul 18, 2012 5:47 pm
Any way to do this?
hunternet93
Re: Remove RPI Logo on startup
Thu Jul 19, 2012 1:57 am
I believe the logo is compiled into the kernel. You'd need to recompile the kernel to get rid of it, which may or may not be worth the trouble.
jojopi
Thu Jul 19, 2012 6:52 am
Add logo.nologo to /boot/cmdline.txt .
khawar
Fri Sep 21, 2012 2:12 pm
jojopi wrote:Add logo.nologo to /boot/cmdline.txt .
Thanks. Works perfectly.
Any way to replace the logo with another image?
aaa801
Fri Sep 21, 2012 4:46 pm
Its in the kernel.
geekuskhan
Fri Sep 06, 2013 12:19 am
Where in the kernel?
hunternet93
Sat Sep 07, 2013 1:51 pm
geekuskhan wrote:Where in the kernel?
Try this: http://www.arm9board.net/wiki/index.php ... _boot_logo
MarkFoley
Tue Nov 26, 2013 3:09 am
Is there a way to remove the logo *after* it finishes booting? It's kind of cute to have it there during, but needs to go away after since it chews up a lot of no-scrolling real-estate, esp. on a 7" screen.
jojopi
Tue Nov 26, 2013 9:04 pm
The logo is overwritten the first time you switch consoles (Ctrl+Alt+Fn), scroll back (Shift+PgUp), or clear the screen (Ctrl+L at the bash prompt).
Also, if you set a console font with "sudo dpkg-reconfigure console-setup", or in /etc/default/console-setup, the logo will disappear automatically during the boot sequence, as a side-effect of re-drawing the screen in the new font.
Tue Nov 26, 2013 9:10 pm
jojopi wrote:The logo is overwritten the first time you switch consoles (Ctrl+Alt+Fn), scroll back (Shift+PgUp), or clear the screen (Ctrl+L at the bash prompt).
You can change that in /etc/inittab - find these lines
1:2345:respawn:/sbin/getty --noclear 38400 tty1
2:23:respawn:/sbin/getty 38400 tty2
3:23:respawn:/sbin/getty 38400 tty3
4:23:respawn:/sbin/getty 38400 tty4
5:23:respawn:/sbin/getty 38400 tty5
6:23:respawn:/sbin/getty 38400 tty6
Remove the --noclear from that #1 getty on pts/0.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
Who is online
