rcooke
PoE i/o board design?
Wed Jul 22, 2015 2:53 am
Has anybody seen an I/O board for the Compute Module that incorporates 10/100/1000 compatible Power over Ethernet to run the Pi?
I'm working on a project for a remote location that has PoE hub nearby. And I have to fit into a small space.
The CM size is fine. I just need to find an I/O board with PoE, USB, and the I/O header.
Or a reference design for PoE and the CM?
Thanks in advance!
Rich.
Re: PoE i/o board design?
Wed Jul 22, 2015 4:46 am
rcooke wrote:Has anybody seen an I/O board for the Compute Module that incorporates 10/100/1000 compatible Power over Ethernet to run the Pi?
Thanks in advance!
Rich.
This is a PCB for a standard RPi add on, it is unlikely you will find a ready made carrier board and will have to design / manufacture your own:
http://www.silvertel.com/component/cont ... i-poe.html
https://www.raspberrypi.org/documentati ... /README.md
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
rcooke
Wed Jul 22, 2015 12:00 pm
Great! Thanks for the link to that add on.
Cheers!
Return to “Compute Module”
