herbfargus
Wifi Bash Script
Sun Jul 19, 2015 12:13 am
I'm really new to coding and the Raspberry Pi, but I have played around with it, and just thought I'd share with the community what I've been working on. I've used wpa_gui and wicd-curses and varying other methods of connecting to wifi, but when it comes to very basic terminal scripts it seems all of them lacked a comprehensive overview of connections to different security types like WEP, open networks, hidden SSID's, and static ip's. I use my Pi for specific things and I don't like the gui's and daemons taking up processing but I also don't like typing in wifi configs manually either so my script is a simple terminal gui for beginners to connect to wifi.
This script is a simple terminal GUI using whiptail that can connect
-WPA/WPA2
-WEP
-Open Networks
-Static IP's
-Hidden SSID's
to install-
download the script
wget https://raw.githubusercontent.com/HerbFargus/Raspberry-Pi-Wifi-Scripts/master/raspberrypiwifi.sh
type the following to make it executable
sudo chmod +x raspberrypiwifi.sh
then you'll want to run it with sudo
sudo ./raspberrypiwifi.sh
for now it only modifies /etc/network/interfaces but in the future I have plans to integrate wpa_supplicant.conf so it can be used with multiple networks. I know the code is a bit redundant and can definitely be improved but I'm open to new ideas and suggestions for improvement :)
It's based on
https://github.com/Death259/PiAssist
with tips taken from here
viewtopic.php?t=7592
bbmark
Re: Wifi Bash Script
Sun Aug 02, 2015 3:46 am
This is the most useful script I have found since I started working with the Raspberry Pi. I worked for many hours trying to get my Pi to connect to my wifi with the Edimax 7811. My router is set to wpa2. I could not figure out the correct combination of the files to get it to connect. I was able to connect my Pi to the internet with an Ethernet cable and then simply cut and paste the instructions you gave in this post and bam! I could actually scan for wifi sites and enter my site and it connected. Thanks so much. Brian.
herbfargus
Sun Aug 02, 2015 5:40 am
I'm glad it was useful to you! Just for reference I compiled a list of basically every possible configuration for wireless networks there is- that way for people who don't have an ethernet cord can set it up manually without needing to download my script. There are two main methods of configuring wifi-
1. only editing /etc/network/interfaces
2. editing both /etc/network/interfaces and /etc/wpa_supplicant/wpa_supplicant.conf (your network SSID and password will be added to wpa_supplicant whereas interfaces is edited to reference wpa_supplicant- this way enables you to be connected to multiple networks/ have it automatically reconnect if your router resets for some reason. I much prefer this way.
I could put it all on one code block but to eliminate any doubt, I'll put each full configuration in.
1. /etc/network/interfaces
WPA/WPA2
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
auto wlan0
iface wlan0 inet dhcp
   wpa-ssid "NETWORK_NAME"
   wpa-psk "NETWORK_PASSWORD"
WEP
auto lo
allow-hotplug wlan0
auto wlan0
  wireless-essid NETWORK_NAME
  wireless-key WEP_KEY
OPEN NETWORK
auto lo
allow-hotplug wlan0
auto wlan0
  wireless-mode managed
HIDDEN SSID
auto lo
allow-hotplug wlan0
auto wlan0
   wpa-scan-ssid 1
STATIC IP
auto lo
allow-hotplug wlan0
auto wlan0
iface wlan0 inet static
   wpa-ssid "NETWORK_NAME" #(set these lines for their respective encryption type- wpa, wep, etc.)
address 192.168.0.110 #(This is the IP you want your raspberry pi to have)
netmask 255.255.255.0 #(This is almost always the same)
gateway 192.168.0.1 #(almost always the same as well. you can verify with netstat -nr)
____________________________________________________________________________________________________________________________________________________________________________________________________
2. WPA SUPPLICANT
/etc/network/interfaces when using wpa_supplicant.conf
wpa-roam (roaming PREFERRED)
auto lo
allow-hotplug wlan0
auto wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
wpa-conf (non roaming)
auto lo
allow-hotplug wlan0
auto wlan0
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
wpa-roam (roaming static IP PREFERRED)
auto lo
allow-hotplug wlan0
auto wlan0
iface default inet static
wpa-conf (non roaming static IP)
auto lo
allow-hotplug wlan0
auto wlan0
WPA/WPA2
update_config=1
network={
    ssid="NETWORK_NAME"
    psk="NETWORK_PASSWORD"
WEP
update_config=1
network={
     ssid="NETWORK_NAME"
     key_mgmt=NONE
     wep_tx_keyidx=0 #this forces it to use wep_key0
     wep_key0=YOURWEPKEY
OPEN NETWORK
update_config=1
network={
    ssid="NETWORK_NAME"
    key_mgmt=NONE
HIDDEN SSID
update_config=1
network={
    ssid="NETWORK_NAME" # it can be any encryption type, just make sure to add the "scan_ssid=1" line after your settings.
    key_mgmt=NONE
    scan_ssid=1
KLL
Mon Aug 03, 2015 2:26 am
great documentation ( but i did not try the bash script, though it looks nice )
i ref. to
- WPA/WPA2 STATIC IP
   address 192.168.1.xxx
not only that it works, also with this it is possible to start NOOBS (silent install ) WIFI ONLY static IP
means fresh noobs SD, edit ... to silent install, see also http://kll.engineering-news.org/kllfusi ... icle_id=94 "noobs noir"
and add in
/os/Raspbian/partition_setup.sh
sed /tmp/2/etc/network/interfaces -i -e '/wpa-conf/d'
sed /tmp/2/etc/network/interfaces -i -e 's|iface wlan0 inet manual|iface wlan0 inet static|'
sed /tmp/2/etc/network/interfaces -i -e '/iface wlan0/a\wpa-ssid "My-ssid" '
sed /tmp/2/etc/network/interfaces -i -e '/wpa-ssid/a\wpa-psk "We-love-Raspberry-Pi" '
sed /tmp/2/etc/network/interfaces -i -e '/wpa-psk/a\address 192.168.1.101'
sed /tmp/2/etc/network/interfaces -i -e '/address/a\gateway 192.168.1.1'
put noobs noir SD in RPI with usb hub powered WIFI adapter, power up and wait 35min,
login putty SSH pi@192.168.1.101 ( even without HDMI or access to router dhcp info... (there would find a second IP..))
( you only must be sure that IP "101" is not used by any other device in the network / so ping first )
while in a raspbian only image i could edit cmdline.txt [space]ip=192.168.1.101
but i would not know how to pre set WIFI also ( from DOS) unless it would be delivered
with the "source /boot/interfaces.conf" switch in /etc/network/interfaces... there's lot to learn
but again, thanks for this great WIFI summary.
