mmkw43
No hdmi audio
Fri Jul 17, 2015 8:51 pm
all of a sudden, nothing after never having a problem. I have triple checked everything in setup and config file -- hdmi is being forced everywhere. the monitor plays audio, the connections have all been exercised and zilch.
can't even play a simple script -- even tried aplay and mpg321 -- even made sure amixer is setup right.
shutdown, rebooted you name it.
is there a problem with the PI just losing audio like this?
mmkw43
Re: No hdmi audio
Sat Jul 18, 2015 4:30 pm
try no audio period.
no hdmi or analog -- yet every config item was correct for each and everything else on the pi is working flawlessly. i even get a message in terminal that aplay is playing the file but can't hear a thing.
can i reinstall a driver? anything? i've spent hours on this.
mmkw43
Re: No hdmi audio
Sat Jul 18, 2015 10:37 pm
just to make this post of value -- my problem was....
amixer volume was zero and how it got that way is beyond me !
sudo amixer set PCM Playback Volume 90% (fixed it -- 90 or whatever you want)
also handy discovery --
sudo amixer set PCM mute (or unmute) (to mute the audio)
Re: No hdmi audio
Sat Jul 18, 2015 11:10 pm
Ha ha! Yes. That has caught me out on my PC Debian systems. Boot up, no sound, WTF, spend 5 minutes checking cables, speakers and this and that.
I rarely shut these machines down so I always manage to forget it's just the mixer setting.
dc331903
Re: No hdmi audio
Tue Aug 11, 2015 6:19 pm
Wow. For those that can use MPG321 locally but get no sound from MPG321 when issuing commands from SSH and RDP, this was the fix for me.
Not sure why i got sound when consoled in locally but not through SSH, but setting the volume did the trick. Odd
