Ethernet TCP/IP Sniffer
Details:
- Raspbian on Raspberry Pi v1 Model B.
- Similar to pitap (Automatic bridge creation and packet capture multiple network interfaces),
using upstart, bridge-utils and tcpdump (libcap) for capturing the traffic over Ethernet. - SMS Handler written in Python using pySerial (UART)
for communication (send/receive data/instructions) through a GSM/GPRS Module. - LCD 16X2 Display (HD44780) connected through SPI [py-spidev (Python)].
I'm using FPGA DE0-Nano As a SPI-Slave and LCD Controller/Driver (it's a requirement). - Network statistics to be displayed & controlled by a node.js http web server application.
- Use some sort of a parser for dissection and statistics.
Wireshark doesn't fit me as i want to implement my own small scale filtering / basic small network statistics application.
How can i integrate all of the above to run all together?
- Should i use a separate upstart daemons / services for each? not sure how all of those work together?
- Should i share some sort of a db derived from the tcpdump pcap file or can it be avoided?
- Maybe it's better approach to gather all to the node.js app
replacing python with pi-spi for SPI, node-serialport for UART.
and launch tcpdump as a child process or something?
I'll be more than glad for some insights
( Follows my stackexchange post)
