mseth
Hardware Malfunction - Possible short-circuit/overheating?
Wed Jul 15, 2015 5:19 pm
I recently noticed that one of the Pi's I was running for a project suffered from a critical hardware malfunction. It looks like some components on the board exploded and leaked. I'm trying to figure out what could have happened here and prevent it in the future. I should note that I was NOT overclocking the device, and I was monitoring and logging the CPU-temp every minute prior. And just before the failure, the CPU-temp reading was approx. 48*C. This is well-within normal operating temperature from my understanding.
The pi was in a plastic enclosure at the time, and was not exposed to the elements. Upon first inspection it appeared that some of the small components (capacitors/resistors, and small ICs) near the Ethernet/USB controller leaked/exploded. There is a milky white liquid and a white powdery substance in that area as well. I'm attaching some pictures to show this.
The high-res images are linked below --
Full-view: https://www.dropbox.com/sh/qh1s5xp3f92t ... 125303.jpg
Close-up: https://www.dropbox.com/sh/qh1s5xp3f92t ... 125330.jpg
Any help in figuring out what might have happened would be highly appreciated, and I hope I can get to the bottom of this.
Thanks,
