shibata
gpio_keys device tree overlay
Sat Jul 11, 2015 2:55 am
I'm trying to setup gpio_keys to trigger keyboard events on GPIO activity. The desired behavior is using a GPIO pin to send a shutdown key code and halt the system. I know there are other ways of doing that and I'm currently using a simple bash script to read the GPIO, but since there is a gpio_keys driver ready to use and with better integration with the kernel I'm willing to move to it.
I can't get the device tree setup to work. My configuration was based on http://lists.infradead.org/pipermail/li ... 58315.html , https://www.kernel.org/doc/Documentatio ... o-keys.txt and http://developer.toradex.com/knowledge- ... O_shutdown . I tried options from all these sources. Finally I decided to abandon overlays and try compiling bt-blob.dts modified to be sure my changes were loaded, but no luck. Trying to generate other keycodes didn't help either. The code I am testing:
gpio-keys {
    compatible = "gpio-keys";
        newline {
            // also tested with other options
            label = "Newline";
            gpios = <&gpio0 21 0>;
            linux,key-code = <13>;
I'm loading the gpio_keys module, but tried with gpio_keys_polled too. I believe the GPIO isn't even being setup, since /sys/kernel/debug/gpio gives me:
GPIOs 0-53, bcm2708_gpio:
 gpio-47  (led0                ) out lo
zcat /proc/config.gz | grep -i gpio gives me:
CONFIG_BCM2708_GPIO=y
CONFIG_ARCH_NR_GPIO=0
CONFIG_RFKILL_GPIO=m
# CONFIG_MDIO_GPIO is not set
# CONFIG_MDIO_BUS_MUX_GPIO is not set
CONFIG_KEYBOARD_GPIO=m
CONFIG_KEYBOARD_GPIO_POLLED=m
# CONFIG_INPUT_GPIO_BEEPER is not set
CONFIG_INPUT_GPIO_TILT_POLLED=m
CONFIG_INPUT_GPIO_ROTARY_ENCODER=m
# CONFIG_I2C_ARB_GPIO_CHALLENGE is not set
CONFIG_I2C_MUX_GPIO=m
# CONFIG_I2C_CBUS_GPIO is not set
CONFIG_I2C_GPIO=y
CONFIG_SPI_GPIO=m
CONFIG_PPS_CLIENT_GPIO=m
CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
CONFIG_ARCH_REQUIRE_GPIOLIB=y
CONFIG_GPIOLIB=y
CONFIG_GPIO_DEVRES=y
CONFIG_OF_GPIO=y
CONFIG_GPIOLIB_IRQCHIP=y
# CONFIG_DEBUG_GPIO is not set
CONFIG_GPIO_SYSFS=y
# Memory mapped GPIO drivers:
# CONFIG_GPIO_74XX_MMIO is not set
# CONFIG_GPIO_GENERIC_PLATFORM is not set
# CONFIG_GPIO_DWAPB is not set
# CONFIG_GPIO_EM is not set
# CONFIG_GPIO_ZEVIO is not set
# CONFIG_GPIO_PL061 is not set
CONFIG_GPIO_SCH311X=m
# CONFIG_GPIO_GRGPIO is not set
# I2C GPIO expanders:
CONFIG_GPIO_ARIZONA=m
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
# CONFIG_GPIO_PCA953X is not set
# CONFIG_GPIO_PCF857X is not set
# CONFIG_GPIO_SX150X is not set
CONFIG_GPIO_STMPE=y
# CONFIG_GPIO_ADP5588 is not set
# CONFIG_GPIO_ADNP is not set
# PCI GPIO expanders:
# SPI GPIO expanders:
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MCP23S08 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_74X164 is not set
# AC97 GPIO expanders:
# LPC GPIO expanders:
# MODULbus GPIO expanders:
# USB GPIO expanders:
CONFIG_W1_MASTER_GPIO=m
# CONFIG_CHARGER_GPIO is not set
CONFIG_POWER_RESET_GPIO=y
# CONFIG_POWER_RESET_GPIO_RESTART is not set
# CONFIG_SENSORS_GPIO_FAN is not set
# CONFIG_GPIO_WATCHDOG is not set
# CONFIG_SSB_DRIVER_GPIO is not set
# CONFIG_BCMA_DRIVER_GPIO is not set
# CONFIG_HTC_EGPIO is not set
CONFIG_IR_GPIO_CIR=m
CONFIG_BACKLIGHT_GPIO=m
# CONFIG_USB_GPIO_VBUS is not set
CONFIG_LEDS_GPIO=y
CONFIG_LEDS_TRIGGER_GPIO=y
# CONFIG_EXTCON_GPIO is not set
Also, I'm running Arch here. Am I missing something? Can someone with more device tree experience help?
Thanks in advance
PhilE
Re: gpio_keys device tree overlay
Sat Jul 11, 2015 12:54 pm
If you look here you will see that the label for the gpio node is called "gpio", so it should be referred to using "&gpio" (not "&gpio0"). If you try:
sudo vcdbg log msg
you should find some error messages because the loader can't locate the "gpio0" label.
Everything else looks plausible, so you may find that deleting the "0" is all you need to do.
FYI you can examine the active device tree in /proc/device-tree. Navigating through all of the directories and hexdumping binary files is a bit tedious, but there is a better way:
dtc -I fs /proc/device-tree
will give you a decompiled version. It will have lost the labels and gained some phandles, and some properties may have become an array of hex bytes, but it isn't too hard to read.
ShiftPlusOne
Sat Jul 11, 2015 1:31 pm
Don't know if this overlay is 100% cromulent, but it works for me:
/dts-v1/;
/plugin/;
	compatible = "brcm,bcm2835", "brcm,bcm2708", "brcm,bcm2709";
	[email protected] {
		target-path = "/soc";
		__overlay__ {
			keypad: keypad {
				#address-cells = <1>;
				#size-cells = <0>;
				[email protected] {
					label = "Test BTN0";
					linux,code = <0x100>;
					gpios = <&gpio 13 1>;
				[email protected] {
					label = "Test BTN1";
					linux,code = <0x101>;
					gpios = <&gpio 16 1>;
				[email protected] {
					label = "Test BTN2";
					linux,code = <0x102>;
					gpios = <&gpio 19 1>;
				[email protected] {
					label = "Test BTN3";
					linux,code = <0x103>;
					gpios = <&gpio 20 1>;
				[email protected] {
					label = "Test BTN4";
					linux,code = <0x104>;
					gpios = <&gpio 21 1>;
				[email protected] {
					label = "Test BTN5";
					linux,code = <0x105>;
					gpios = <&gpio 26 1>;
PhilE
Sat Jul 11, 2015 1:56 pm
Totally cromulent.
It's good of you to embiggen the example.
shibata
Sun Jul 12, 2015 4:29 am
Thanks for the help. At first I though it still wasn't working because I was using showkey to test the buttons, which wasn't giving any output, but I saw gpio_keys automatically loaded and cat /dev/input/event0 gave me data. Any idea why keys won't appear on terminal/applications?
EDIT: Nevermind, I mistakenly chose RIGHTCTRL as the GPIO key.
doubleodoug
Sat Sep 05, 2015 1:10 am
Did this get figured out? I've got the switch working and it's recognized as XF86PowerOff, same as a power button on a USB keyboard, but linux doesn't actually shutdown when this key is pressed and I have no idea how to turn that on. X11 will if configured to, but this doesn't help unless the X server is running. The udev rule at http://developer.toradex.com/knowledge- ... O_shutdown doesn't seem to work.
doubleodoug
Sat Sep 05, 2015 6:11 pm
Nevermind, the systemd maintainers added this ability to the latest version. http://lists.freedesktop.org/archives/s ... 33800.html. This should filter down to raspbian eventually.
shibata
Sun Sep 06, 2015 3:20 am
You will have to edit ID_PATH to match your ID. On mine,
SUBSYSTEM=="input", KERNEL=="event*", ENV{ID_PATH}=="platform-soc:keypad", ATTRS{keys}=="*116*", TAG+="power-switch"
works.
pidisaster
Mon Feb 10, 2020 9:14 pm
ok i know this is an old post just don,t where to ask
i am trying to use GPIO pins (adafruit 2.4 display) to give keyboard shortcuts
this is used in tunerstudio tuning software http://www.tunerstudio.com/index.php/tuner-studio
would this be the proper thing to do !?
i did manage to get 2 buttons to work simulating a single character
/dts-v1/;
/plugin/;
	[email protected] {
		__overlay__ {
			keypad: keypad {
				#size-cells = <0>;
				[email protected] {
					label = "RightCtrl-ArrowRight";
					linux,code = <97,106>;
					gpios = <&gpio 5 1>;
				[email protected] {
					label = "LeftAlt-A";
					linux,code = <56,30>;
					gpios = <&gpio 6 1>;
				[email protected] {
					label = "LeftAlt-S";
					linux,code = <56,31>;
					gpios = <&gpio 12 1>;
				[email protected] {
					label = "LeftAlt-D";
					linux,code = <56,32>;
				[email protected] {
					label = "LeftAlt-B";
					linux,code = <56,48>;
				[email protected] {
					linux,code = <0x16>;
assembled with
sudo dtc [email protected] -I dts -O dtb -o /boot/overlays/breadboard.dtbo breadboard.dts
PhilE
Mon Feb 10, 2020 10:14 pm
The gpio-keys driver only generates one event number for each key - the first value of the linux,code property; anything else is ignored.
pidisaster
Tue Feb 11, 2020 5:20 pm
is there another way to achieve this?
i don,t think the developer will change the key-combination to a single key so that accidental key presses will not do damage to the engine
i was also looking at trigger-happy as possible solution or python uinput
but alas i am not very proficient in programming :roll:
PhilE
Tue Feb 11, 2020 5:46 pm
Not that I can think of, but you might get more help in a different forum such as Interfacing.
pidisaster
Thu Feb 20, 2020 5:52 pm
well not much luck on the interface forum
viewtopic.php?f=44&t=265210
i was thinking to use the before mentioned code to simulate a single key-press and use evmapy
https://github.com/kempniu/evmapy
to turn that single key-press into a simulated keyboard combination
as i am not sure if the GPIO pins can be turned on as a detectable device by evmapy
without the mentioned code!? :shock: :?
would this be a somewhat workaround solution?
PhilE
Thu Feb 20, 2020 9:02 pm
I've answered as much as I can, having not attempted the kind of key remapping you require. Just keep searching and trying - the worst that can happen is that you might learn something.
pidisaster
Sun Feb 23, 2020 7:35 pm
well i have learned something :ugeek:
but i am only getting an echo on gpio 5 and 6 with the following code
/dts-v1/;
/plugin/;
	[email protected] {
		__overlay__ {
			keypad: keypad {
				#size-cells = <0>;
				[email protected] {
				[email protected] {
				[email protected] {
				[email protected] {
				[email protected] {
				[email protected] {
					gpios = <&gpio 18 1>;
this is on a pi4 (BCM2711 SoC)
there is an internal pull up on GPIO 5 and 6 ( 3.3 volt ) but not on the others
is this a code issue!?
PhilE
Sun Feb 23, 2020 9:05 pm
As you say, GPIOs 0-8 have a default pull up, while GPIOs 9-27 pull down. This is the reset state designed into the GPIO block, and the firmware doesn't change it unless asked to with a dt-blob, ”gpio=" directive, etc.
You can get the pinctrl driver to change the pulls for you by creating a group ("brcm,pins", "brcm,pull" and "brcm,function") under the gpio DT node and referring to it from the pinctrl-0 property of your keypad node. See the standard gpio-key overlay for an example.
pidisaster
Tue Feb 25, 2020 8:25 pm
don,t know if this was the way to do it but at-least all the buttons work now
so i managed to use the GPIO buttons to simulate the arrow keys
that,s something
PhilE
Tue Feb 25, 2020 8:47 pm
A slightly neater hack would be to add the following to config.txt:
gpio=12,13,16=ip,pu
Return to “Device Tree”
