Phixxy
Boot Text Color
Tue Jul 17, 2012 9:48 pm
Is there a way to change the color of the text when the Raspberry Pi is booting up?
jojopi
Re: Boot Text Color
Tue Jul 17, 2012 10:12 pm
Yes! Add the following to the end of the first line of /boot/cmdline.txt:
 vt.default_red=0,255,255,255,255,255,255 vt.default_grn=0,102,102,102,102,102,102,102 vt.default_blu=0,51,51,51,51,51,51,51
Phixxy
Re: Boot Text Color
Tue Jul 17, 2012 10:16 pm
jojopi wrote:Yes! Add the following to the end of the first line of /boot/cmdline.txt:
I would paste all of that? or just
If i wanted green text. Id rather have purple if thats possible.
EDIT: I pasted all of the code, it made the font an orangey color. So this does work. How can I change it to a pinkish/purple color?
Phixxy
Re: Boot Text Color
Tue Jul 17, 2012 11:02 pm
For some reason it wont let me edit my above post. I got purple text by adding
at the end of the first line of /boot/cmdline.txt
I'm not sure why the one labeled "grn" makes the color purple. Blu made the color pale yellow, and red makes it a pale orange. Thanks everyone above this post =)
AndrewS
Re: Boot Text Color
Wed Jul 18, 2012 1:01 am
I found a brief bit of documentation here http://redsymbol.net/linux_boot_parameters/2.6.25/
And it seems the default colours are here http://lxr.free-electrons.com/source/dr ... vt.c#L1049
Basically it looks like the console has a 16-colour palette, and these commands let you set the red, green and blue components of each colour in the palette.
I.e. colour0 has value (red0, green0, blue0), colour5 has value (red5, green5, blue5), etc.
So by setting just vt.default_grn, the red and blue channels will keep their default values as show in the second of my links, and you're changing just the green component of the colours.
Just for reference, I made a colourstrip of the default colours, according to the vt.c file linked above 8-)
Taste the rainbow
Phixxy
Re: Boot Text Color
Wed Jul 18, 2012 1:54 am
So by limiting the green, i mixed blue and red, to make purple. Makes sense now. Thanks a ton, now I can fine tune the color I want. =)
Phixxy
Re: Boot Text Color
Wed Jul 18, 2012 2:32 am
Again, I cannot edit my above post. Why is this?
Anyway. Warning to anyone that is going to try to change their boot font colors, DO NOT change the zero in the sequence of numbers. Doing this will change the background color of the terminal and can make everything un-readable. I had to ssh into my raspberry pi to change it back.
mahjongg
Re: Boot Text Color
Wed Jul 18, 2012 2:35 am
Phixxy wrote:Again, I cannot edit my above post. Why is this?
If this is one of your first edits you cannot edit your previous post, in the future you will!
That or a naughty moderator made an edit the same time you did. :roll:
And yes, black on black is a bit hard to read. LOL. :lol:
itimpi
Re: Boot Text Color
Wed Jul 18, 2012 2:36 am
If this is one of your first three edits you cannot edit your previous post, in the future you will!
There is also a timeout (I think it is 30 minutes) after which posts cannot be edited regardless of how many posts you have made.
mahjongg
Re: Boot Text Color
Wed Jul 18, 2012 2:39 am
Yes, that too, (although it doesn't apply to me anymore, but I remember that from when I was a wee lad). :P
Phixxy
Re: Boot Text Color
Wed Jul 18, 2012 2:42 am
Purple on purple is hard to read also.
Thanks everyone for helping me out. This is why I have loved the linux community since I started toying around with linux. Hopefully I will get a more serious attitude in learning about linux more. I do like playing around without a gui, something new to me.
JacketAlTrades
Re: Boot Text Color
Sat Jan 31, 2015 2:04 am
OK, so I know this is what I need, but I don't seem to be grasping it right. I want to get a green text, similar to the 3rd from the left color from the color palette above. I have tried adding the red and blue=0 comments, so that would "zero out" those colors and allow only green, but instead I only get a deep yellow colored text. Any help would be greatly appreciated.
Thanks All!
