Thra3h
Letting Owncloud Access A USB
Thu Jul 09, 2015 9:09 am
I'm trying to setup owncloud 8 on my RPi2 and when I enter my local IP this is where I get - normal.
I've mounted my USB to /media/owncloud and I can store files there, and then view them on my computer - so the USB is working.
I believe I have given owncloud the correct permissions to view and write to the USB drive:
sudo chown -R www-data:www-data /media/owndrive
Then I configure the Storage And Database setting and set it to /media/owndrive, but when I click Finish Setup, it displays this:
Any help would be appreciated greatly! I've probably done something simple that's causing the problem, so...
Thanks,
Stephen
Thra3h
Re: Letting Owncloud Access A USB
Sat Jul 11, 2015 9:43 pm
Just noticed something...
Will look into it some more today...
Thra3h
Sat Jul 11, 2015 11:08 pm
Still not working...
I'm probably missing something fairly simple. Help would be appreciated greatly!
Thra3h
tpylkko
Sun Jul 12, 2015 10:48 am
try mounting it somewhere where you are sure it has permissions to see whether that might be the reason?
Sun Jul 12, 2015 4:40 pm
If your USB stick is formatted as FAT, vFAT, exFAT or NTFS then ALL security is done on the mount command. You can't use chown and chmod, it simply does not work.
Thra3h
Sun Jul 19, 2015 9:43 am
DougieLawson wrote:If your USB stick is formatted as FAT, vFAT, exFAT or NTFS then ALL security is done on the mount command. You can't use chown and chmod, it simply does not work.
That worked for me! Thanks so much! Ended up changing the auto-mount line to give permissions to 'www-data'. :D
Return to “Raspberry Pi OS”
